SOURCE: DeLonghi 50 Pint dehumidifier DE 500P won't turn back on
If it is not responding when you try to activate the shutoff button and are still not recieving an acknowledgement that the bucket is full you may hav a defective shutoff button. Try contacting the Manufacturer and see if you can purchase just the button. This i a common part and the price is usually reasonable. If you feel very technical inclined you can remove the button and touch the 2 wires together simulating a closed contact. The dehumidifier should now acknowledge the bucket is full. If you recieve the notification then the button is bad. If you found this solution helpful please rate it.
Thanks - Tech101
SOURCE: I want to change my deLonghi Dehumidifier from
You may have a older model that has a collector tank with a protruding tube on it. If so just cut the end off the tube and slide on a piece of clear 9.5mm internal diameter PVC / Rubber tubing suitable for a fish tank air / water pump and secure it with a nylon tie wrap.
Continuous external draining for newer models with clear collection tanks.
If the appliance is to be operated for long periods of time but you are unable to empty the tank, you are recommended to use the continuous drain facility.
• Drill the inside of the drain spout using a small drill bit. This is located behind the rear grlle in the lower centre of the opening.
• Fasten the rubber hose to the spout. For models without drain hoses supplied, we suggest you purchase a rubber hose around 2m long, with an internal diameter of 9.5 mm.
• Make sure that the hose is not higher than the spout, otherwise water will remain in the tank; also check that the hose is not twisted. N.B: Keep the rubber bung. You will need it to plug the hose or close the spout if you revert to draining into the tank
Testimonial: "Very helpfyl I think. I will se when I get home where the drilling needs to occur."
SOURCE: DeLonghi DEN500P Dehumidifier Humidistat
I have the delonghi DEN500P and the unit runs but does not condense any moisture? The appropriate buttons have been set to bring the unit humidity setting well below humidity in room
SOURCE: New Delonghi Dehumidifier,5 gal:When units beeps
It should resart on its own after putting the empty bucket back in. The beep is to let you know that the bucket full and it shuts off the humidifier until the bucket is emptied and put back into the proper position.
SOURCE: i have a delonghi dehumidifier type cf08e but have
You can get the manual on the link below.
http://www.delonghi.com.au/support/instruction_manuals/CFO8E_im.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Here
is a tip that explains what can be happening to make the dehumidifier
show that the bucket is full when it is not.
Dehumidifier
Problem It shows Bucket Full
heatman101
