The vertical adjustment works for both driver side and passenger side mirrors, although it is tempermental. The horizontal "right" toggle works for both sides, but it needs some massaging. The horizontal "left" toggle ("out" for driver's side and "in" for passenger side) adjustment doesn't work at all. Do you have any suggestions?
SOURCE: no power on front passenger door
Check the connections between the door and the body, not the panel on the door. If a wire was pinched between the door and body that could be the problem. There should be a boot between door and body, peal that back and look for damaged or grounded wires. Repair as necessary.
Joel
SOURCE: Is a fuse blown? My passenger side door's electrical won't work.
Generally fuses control an entire system, in this case it sounds as if you have a wiring problem such as a plug has come undone that wires the door equipment. Check the wiring that goes to the door, follow it to your problem.
SOURCE: replace side view mirror 2002 chevy tahoe
Once you've purchased a replacement mirror glass based on your specific make, model and year simply follow the steps below:
SOURCE: adjust dr side door
If you can grab the end of the door and lift on,and there's movement, what you need is the door hings bushing, most all auto parts sell this as a kit, cost about $6.00, the only adjustment you will have will be at the striker bolt, that the part where the door latch, latches to, to hold the door close, it unscrews and it will have some adjustment, but not much.There not adjustment for door hing.
SOURCE: i have a 2006 chevy trail blazer, the drivers side
Problems WithChevy TrailBlazers
ElectricalProblems
Some of the mostcommon problems with the TrailBlazer involve the vehicle's electrical systemand accessories. Many drivers have experienced problems with the dashboardgauges, including the fuel gauge, speedometer and "check engine"warning light. Additional electrical problems include power automatic doorlocks and windows that fail to work or operate intermittently. These problemscan be difficult to diagnose as they can result from anything from a faultybattery to problems with the wiring or other electrical components.
Read more: Problems With Chevy TrailBlazers ' eHow.com
A fuse contains a thin metal bridge between two terminals. When too muchelectrical current is drawn through the fuse the bridge melts, breaking thecircuit. This feature prevents damage to electrical components and limits thepossibility of a fire.The Chevrolet Blazer utilizes small fuses to protect thevehicle's wiring harness from overload. These are typically plug-in blades, notthe glass-barrel fuses used in older vehicles.
Location
The fuse panel ona Chevy Blazer is located on the driver's side of the firewall beneath thedashboard. Some later models may be equipped with a fuse panel cover. To removethe cover, pull the retaining clips loose on each side and lift the cover fromthe panel.
Replacing a Fuse
Locatethe fuse you believe is burned out by its label or use the owner's manual as aguide. To remove the fuse, you may need needle-nose pliers; don't put too muchpressure on the fuse or you could crack the casing. Examine the thin metalstrip between the two terminals. If it is broken, scorched or deformed, it mustbe replaced.
Read more: Fuse Box Instructions for a Chevy Blazer ' eHow.com
