DAP-1522 WIZARD need to upgrade firmware
Posted by jlemons1 on
White Zombie
    Top Expert:
  • 4,961 Answers
You can download the latest version of the firmware you need below. Just determine if you have dap-1522 or dap-1522 rev.B.
The serial number, hardware version/revision information, MAC address and model number, will be located on a label on both the outer box, and on the adapter itself, usually attached to the bottom of the unit. See the example picture on the bottom of this page.
latest dap-1522 firmware:
ftp://ftp.dlink.com/Multimedia/dap1522/Firmware/dap1522_firmware_141b.bin
latest dap-1522 revB firmware:
ftp://ftp.dlink.com/Wireless/dap1522_revB/Firmware/dap1522_revB_FW_203b.bin
Install instructions for the firmware are on page 41 in this pdf:
ftp://ftp.dlink.com/Multimedia/dap1522/Manual/dap1522_manual_130.zip
Here is a great setup video for it:
http://www.youtube.com/watch?v=lYJPGqtyFZU
Posted on Jun 06, 2012
How to assign static IP of my access point DAP 1150 to my pc
From your computer, get the MAC-address of your network adapter.
Configure the router to always give out the same IP-address for that MAC-address.
Jul 12, 2014 | D-Link DAP-1522 Xtreme N Duo Wireless...
JE NE PEUX PAS INSTALER DAP 1360
Access D-Link's support-site: ftp://ftp2.dlink.com/PRODUCTS/DAP-1360/
Choose 'REV. A' or 'REV. B' or 'REV.C'.
Download the instructions for your router.
Feb 16, 2014 | D-Link DAP-1522 Xtreme N Duo Wireless...
Dap-1320 cant connect on internet
You posted your question in December 2013.
Do you still need an answer?
Dec 16, 2013 | D-Link DAP-1522 Xtreme N Duo Wireless...
Cannot access either dlinkap or 192.168.0.50 via web browser in order to set DAP-1360
Connect your computer to the router.
Assuming Windows 7, click the "Start" button.
Into the search-box, type 'CMD' and press ENTER.
Type 'IPCONFIG /ALL'.
Look for the IP-address of the "gateway" (or "DHCP-server").
Type that IP-address into your web-browser.
Nov 24, 2013 | D-Link DAP-1522 Xtreme N Duo Wireless...
Dlinkap
You can do a reset to default settings. OR using the on-line setup, change/remove Security Key, refer to the User Manual here: http://www.dlink.com/-/media/Consumer_Products/DAP/DAP%201522/Manual/DAP%201522_Manual_EN_US.pdf
May 16, 2013 | D-Link DAP-1522 Xtreme N Duo Wireless...
Dap-1522 setup wizard
The serial number, hardware version/revision information, MAC address and model number, will be located on a label on both the outer box, and on the adapter itself, usually attached to the bottom of the unit. Example picture on the bottom of this page.
Jun 05, 2012 | Computers & Internet
Cant open the link to setup the router
Refer to page 3 of the Quick Install Guide listed on the web site below.
There are multiple ways to configure this router and do not wish to provide HOW TO without knowing how you have it set-up.
www.dlink.com/products/default.aspx?pid=DAP-1522&tab=3
Apr 04, 2011 | D-Link DAP-1522 Xtreme N Duo Wireless...
Cannot connect to Dlink DAP-1522 at 192.168.0.50. Unit is plugged into home network router.
Hi. Is this to change its settings?
Plug directly in the DAP-1522.
Set your PCs network settings under TCP/IP, alternate config:
IP Address: 192.168.0.10
Subnet mask: 255.255.255.0
Default Gateway: 192.168.0.50
Give it a try.
Regards,
Nov 05, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Dlink dap 1522
I think I was having a similar problem with my DAP-1522 ... FW Version 1.10 being used as an access point. I recently discovered that I was not able to connect to the configuration pages using a web browser by typing in it's IP address (192.168.0.50). When I originally set this up device up on my network, it worked just fine, but at some point in time, it stopped working. My solution to this problem was to set the switch on the back of the 1522 from Auto to AP, then re-boot the DAP-1522 by removing power, waiting 10 seconds, then plugging power back in. Once the AP re-booted, I was then able to access the configuration login page by typing 192.168.0.50 into my browser. My DAP-1522 access point is connected via port 1 to my D-link router, a DGL-4100, via a DGS-2208, 8 port gigabit switch. Hope this helps!
Aug 16, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Computers & Internet Logo
262 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
