Hardware & Accessories Logo
jennie Posted on Jun 05, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Manuals al900mtss transformer - Intermatic Hardware & Accessories
Gene Haynes
Level 3:
  • Intermatic Master 5,391 Answers
  • Posted on Jul 01, 2012
Gene Haynes
Intermatic Master
Level 3:
Answers
5391
Questions
0
Helped
2606557
Points
14124
Copy following link for Intermatic / Malibu low voltage transformers manuals:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Copy following link for Low voltage Intermatic pool transformers:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#pool-lights
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
E76-LE2-2/45 TK-1 transformer data sheet
Service manual says it has already selectable voltage transformer in it having selection of 120V, 220V and 240VAC. Anyway see page 9 of service manual
ROTEL RX-855 Service Manual download, schematics, eeprom, repair info for electronics experts (elektrotanya.com)
2answers
Sony str-av1020 reciver Power supply transformer burned!
http://www.sony.owner-manuals.com/STRAV1020-service-manual-SONY.html
Resetting a tripped kitchler low voltage transformer
Model number is not known.
I did not know that Kitchler transformers have a circuit breaker.
Usually they have an override switch.
Did you set the timer to override, what does your product manual say?
Is the transformer humming? Kitchler transformer are supposedly non-audible, but there should be some indicating sound. The humming sound indicates the transformer is working.
Does the unit have photoeye? Cover photoeye with black tape.
Test outlet with circuit analyzer.
Check outlet voltage: if you have 120Volt then output is 10% or 12Volts. If you have reduced voltage, then output is still 10% but might be lower than needed to operate bulbs.
Plug timer into different outlet.
Test output terminals with low voltage tester.
Did you have power outage or nearby lightning strike? Transformers are not protected from surge.
Suggest you contact kitchler.
Kitchler.com website is useless
888-412-4877
7711 E Pleasant Valley Rd
PO Box 318010
Cleveland, OH 44131
Kitchler products are probably warranted through the seller.
Kitchler product manuals are almost non-existent.
Scan your product operating manual and parts list into .pdf format and post on web for others to access.
2answers
Technosonic model CDC 206 Transformer internal fuse blown what volatge is the transformer so it can be replaced
Due to safety regulations many makers request that transformers are replaced with EXCAT replacements. Contact the maker or repair center for it.
2helpful
Need Z4000 transformer (trains) manual
We were able to locate a Z4000 transformer manual. Found out our problem was a connection problem with the track and not a problem with the transformer. Thanks anyway.
Dec 31, 2009 • Mth Toys
Transformer Instructions available online??
good day,
hope this link below will solve your problem.
toys
Power transformer problem
You need the service manual for those values. A quick google search shows it costs more than the replacement transformer! http://www.google.co.uk/search?hl=en&q=XG539A00+&meta=
But that is for the 110v version @$21. The same company sells the service manual @$24 or just keep googling.
Top Intermatic Hardware & Accessories Experts
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
