Question about Panasonic ET-RM100 Remote Control
Panasonic CT-25S10H2U Hotel to consumer mode
3 Suggested Answers
6ya staff
SOURCE:
Azrael SRL
  • 11800 Answers
SOURCE: The owner of the hotel
You don't need a clone box to switch between modes, just 2 steps are required:
1. press simultaneously Action and Volume > buttons simultaneously then immediately after
2. press simultaneously Action and Channel ^ buttons simultaneously
If the pressing has been done correctly the OFF message will blink on the screen, signalling the switch of the modes.
Posted on Dec 28, 2010
BElectric
DILLIGAF
  • 1140 Answers
I apologise in advance if I repeat anything you have already been told, but I am only able to see your comments and not the solutions written by other experts.
3 things come to my attention:
1. You should not need a clone box to switch the TV to "NORMAL" mode
2. The availabilty of parental lock in the menu does not indicate that the TV is in normal mode. There is a parental lock setting in both the hotel and normal mode menus.
3. The main menu is accessed by pressing the "ACTION" button. If you are getting the "SETUP" menu when you press the action button, this would confirm that you are still in "HOTEL" mode.
The NORMAL mode menus have graphical icons. The HOTEL mode menu is simply a text menu in list format. Therefore, it is simple to determine which mode you are in after pressing the ACTION button.
Obviously, knowing this doesn't solve your problem. You should be able to switch to normal mode using the buttons on the front panel of the TV (not the remote) as follows:
1. Switch the TV on
2. Press and hold both the "ACTION" button and the "VOL >" button for about 1 second.
3. Release both buttons and, within 1 second, press and hold both the "ACTION" button and the "CH ^" (channel up) buttons for about 1 second.
"OFF" should flash in red in the bottom corner of the screen, indicating that you are in "NORMAL" mode. You can switch back to "HOTEL" mode by repeating the steps above. In this instance "ON" will flash in red in the bottom corner of the screen.
Please note: it can be quite difficult to co-ordinate the button presses and timings correctly, so you may need to try several times. It may also work if you continue to hold the "ACTION" button, then release only the "VOL >" button and then press the "CH ^" button.
If you still cannot switch to normal mode, please make sure each of the buttons on the front of the TV required for switching modes are working correctly. Make sure the "ACTION" button opens the menu, the "VOL >" button increases the volume and the "CH ^" button changes the channel up by one position. If one of the buttons on the front of the TV isn't working then try another TV.
If, having tried all of the above, you cannot return to normal mode, please post back for further assistance.
Regards,
BElectric
Posted on Jan 01, 2011
How do i get my panasonic th37pr9u out of hotel mode....i have tried a few things i found online but no remedy has worked.
Getting out of the hotel mode is very easy. Just go get the Panasonic remote and open your tv. Go near the tv and hold down the V/- button on the television itself. Then use the remote and press the AV button for 3 times. A hidden menu on the television screen will appear. Turn off the "Hotel Mode" from the menu and exit. Do not touch anything from the hidden menu except the hotel mode. Now you can use your tv in normal mode. The remote is required to access the hidden menu so be sure your remote is working and has working or full charged battery before doing the steps above
Read more: I just purchased a Panasonic TH-37PG9U TV from a hotel and can`t get it out of hotel mode. How do I get into normal mode? But I don`t have the remo... - I just purchased a Panasonic TH-37PG9U TV from a hotel and can`t get it out of hotel mode. How do I get into normal mode? But I don t have the remote control :: Ask Me Fast at http://www.askmefast.com/I_just_purchased_a_Panasonic_TH37PG9U_TV_from_a_hotel_and_cant_get_it_out_of_hotel_mode_How_do_I_get_into_normal_mode_But_I_dont_have_the_remo-qna9315338.html#q5576553 you need your remote,this is the one you need,maybe you can find it cheaper,https://www.amazon.com/OEM-Panasonic-Remote-Control-TH-37PWD8BK/dp/B00NRHAZDU
Apr 21, 2017 | Panasonic Televison & Video
How to get Sanyo dp50741 out of hotel mode?!
This is for Panasonic but might help you
Getting out of the hotel mode is very easy. Just go get the Panasonic remote and open your tv. Go near the tv and hold down the AV/- button on the television itself. Then use the remote and press the AV button for 3 times. A hidden menu on the television screen will appear. Turn off the "Hotel Mode" from the menu and exit. Do not touch anything from the hidden menu except the hotel mode. Now you can use your tv in normal mode. The remote is required to access the hidden menu so be sure your remote is working and has working or full charged battery before doing the steps above.
Read more: My 50" sanyo plasma tv is stuck in hotel mode how do i get it out of hotel mode? - When i turn the tv on it says D01--32 and a blue lower case u under it :: Ask Me Fast at http://www.askmefast.com/My_50_sanyo_plasma_tv_is_stuck_in_hotel_mode_how_do_i_get_it_out_of_hotel_mode-qna4904417.html#q5129429
Nov 28, 2015 | Sanyo Televison & Video
How do i get my lg32lx4dc tv out of hotel mode?
You have to enter its service mode option to release the Hotel mode. For that, you should have its 'Service Remote Control'; not the user remote control. It will be best to contact the authorized service center for LG. google.com/+GopakumarGopalan
Jun 08, 2015 | Televison & Video
LED Hotel Mode key?
You have to enter its service mode option to turn ON of OFF and Adjust the Hotel mode options. If you wish to get more details about how to enter hotel mode, and make necessary adjustments, check this link. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timslide option. Never forget to EXIT service mode, after you've done all necessary adjustments.
Jun 28, 2013 | Televison & Video
How do you turn the retail mode off
If you are talking about a set from a Hotel etc only the remote provided to the owner will do that---remotes for commercial sets are different than consumer ones.
Jun 13, 2012 | Emerson Televison & Video
Toshiba hotel mode
"Hotel mode" is usually an option for commercial TVs. In order to get rid of that, you might need "service remote control". Similar used in commercial "Philips" LCD panel sets. I do have the one. But it won't work with Toshiba. check help line and ask to obtain the one. It might cost a bit more, than consumer one, but? that might be your only option. consumer sets have "store" mode, but it defeats easy from regular setup menu. Do you have original remote for TV? Inspect it, if you do. It might be the service one, anyway. Those have "guest", "administrator", "service" modes.
Good luck,
Alex.
Dec 04, 2011 | Toshiba Televison & Video
How to convert a phillip tv from hotel mode to consumer mode without a remote
people stop stealing motel tv's!!!!
Special TV's made for that purpose are manufactured that way. There is no converting them. Give it back.
Nov 22, 2009 | Televison & Video
Akai TV - Stuck in Hotel Mode
M (menu) 7935 (regular menu appears), them press 4725 (menu service appears), then search HTLSRC (position 090), then set value 032 (this value disables Hotel Mode) - TV. Now Hotel Mode is deactivated. It is verified!
M 7935 4725, go to HTLSRC (090), fix 032 - press TV. Good luck!
Jul 28, 2009 | Akai Televison & Video
Getting out of hotel mode
hi have crown tv modle number ctt20001 i think it is stuck in hotel mode
Feb 20, 2009 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
Trying to get channels above 42 to 99
I had the same problem the solution is you have to get institutional remote and reset the tv from commercial mode to consumer mode and then you will have access to the full menu. go to www.phillipsitv.com to get the directions. I actually asked a Hotel could I borrow their master remote used it and took it back and my tv works fine. Hope this helps.
Dec 01, 2007 | Philips Magnavox 27MS343S 27" TV
Open Questions:
Panasonic ET-RM100 Remote Control Logo
80 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
