Fan Unit Replacement for SA-HT65?
The Home Theater system stops working after few mins with a louder sound (Error F61) - when I searched online, I came to know that I need to replace the FAN unit in my Home Theater System. But When I contacted the Panasonic Parts department, they have discontinued the Fan unit (part # REM0089) and they are not able to give the repacemement unit either. Can you please suggest me what is the replacement option available for this FAN unit.
Posted by Thomas on
Russ Hill
  • Audio Player... Master
  • 4,057 Answers
Replacement fans are on ebay, you need to measure the fan, how many wires. etc or do a search of the fan number that is on the fan itself. as long as the fan is the same size from fixing hole top left to fixing hole bottom right and the right voltage and wiring it will work as a cooler fan in the device.
Posted on Jun 30, 2017
5 Related Answers
ABRsvcs
  • 4234 Answers
SOURCE: sa-ht680 service manual
The F61 indicates protect mode. There is a problem with the output stage of the amplifier section and the unit shuts down to prevent further damage. This unit will require service of the amp section. You can try to contact Panasonic for the service manual.
The output amp pac is an RSN311W64D at a cost of $95 plus shipping.
Dan
Posted on Apr 09, 2008
SOURCE: F61
That code means the audio amplifier IC´s are dameged and need to be replaced
Posted on Jan 23, 2010
rc
  • 417 Answers
SOURCE: I have a Panasonic SA-HT650 Home Theater system
A power source problem. Means there is voltage measured at the output/speaker cable connections. Indicates a failure of the amp., or faulty power supply to it.
Just re-check all of your connections, especially speakers. And that the power ac power source from the wall is wired correctly and has proper voltage and grounding.
Posted on Apr 09, 2010
SOURCE: Panasonic SA-HT920 ''F61'' error message
from my experience, I think your player is having a power problem. It must have received excess voltage/irregular power supply which has damaged an IC or capacitor on the power board of the player.
Sometimes this excess power supply might damage the player's main board. This is why it is advice able that you use step down for your player, because DVD player don't need excess power as something might be damaged.
To solve this problem, you will be needing a meter. Open the player, use the meter to read the components on the power board as it will help you discover the component that got damaged and you can then replace the bad component.
But if you do not have the knowledge of fixing this problem, you might be needing the help of a service technician.
Take care.
Posted on May 15, 2010
ak_kharal
SOURCE: Panasonic SA-HT640 home theater unit displays F61
i am facing the same problem. and i dont know how to fix it. please help me.
Posted on Oct 02, 2010
Error Code F61. Do I need a new fan?
it is fault of cooling system, and sound output error, if fan is disconnected or not running F61 comes on screen then nothing happends, power sound ic is the main cause of the device, not only cleaning works, may need to change the the power sound out put ic.
Nov 02, 2015 | Panasonic Sa-pt750 Multi 5 Dvd Player...
Replaced the side fan with the factory part. Now get an f61 error. reconnecting the old fan correects the f61 error. What can be done?
return the new fan as defective and start again with another and mention your issue, either new fan bad or wrong one.
Dec 03, 2012 | Panasonic SC-HT441 Theater System
AFTER A FEW SECONDS MY SYSTEM SHUT DOWN AND SHOWS ME F61 ON THE SCREEM
  1. AFTER A FEW SECONDS MY SISTEM SHUT DOWN AND SHOW ME F61 ON THE SCREEN
Oct 25, 2010 | Panasonic SC-AK300 CD Shelf System
Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
May 12, 2010 | Panasonic Home Theater System System
Repeated F61 fault code on Panasonic Home cinema system Model: SC-HT990 Is it the fan in the sub woofer?
Hello
F 61 error means the failure of FAN
most probably dust in the fan made it to stop working so clean the dust and connect the fan to an external supply of 12v(using red and black wire) for 5 minutes and reconnect it to the unit otherwise replace the fan with new one.
Surely this will solve the problem.
Kind regards
Andrea
Dec 12, 2009 | Panasonic Home Theater System System
Panasonic SA-HT 955 Home Theatre System
The F61 is the shorthand for protect mode. This indicates a problem with the output amplifier section. I don't have a listing for your specific model, but a similar one HT95 lists IC501 as the output amp chip. Check for the marking on the large black IC attached to the heatsink it may be RSN311W. If so, this can be ordered using part number: RSN311W64D-P for $95.20 from tritronicsinc.com.
Hope this helps,
Dan
Aug 28, 2008 | Panasonic Home Theater System System
Error Message F61
Hi guys,
just had the f61 error code on my home theatre system, now i work with samsung dvds and tv's so the background knowledge is there ( i hope), i dont know if u guys noticed the fans making a noise whenever you switched it on before the fault happened but mine were making a hell of a noise, this prompted me to have a look inside and find 2 fans both of which were very dusty, just a 10 minute clean and a 10 min reassemble and im back up and running on all channels.
hope this helps guys
Aug 08, 2008 | Panasonic Home Theater System System
Panasonic Dvd Home Sound system SC-PT950 code f61
The F61 is the coded "protect mode" indication. The internal amp chip has failed. It sounds like this system should still be under warranty. Return it for warranty service. The amp chip will be replaced.
Sorry about hte delayed response. I was away in business for a few days.
Dan
Aug 03, 2008 | Panasonic Home Theater System System
F61
i had the same problem with the error code f61.There are 2 fans,1 external and 1 internal and were both working but were very clogged up with dust thus working harder.Try cleaning them both it worked for me on the SA-HT 990 model
Jan 10, 2008 | Panasonic sa-ht800V Home Theater Audio...
F61
Sound amplifier ic??******** this guy is talking out of his ***.
F61 relates to fan error. There are two fans, one of them is either spinning too slowly or not at all.
This fan can be purchased in any computer store. Just remove it and take it with you.
Jul 28, 2007 | Technics SC-DV290 System
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
