I not able to install memory in second slot. I Install memory in bottom slot, but not able to on top slot. I try to lift pin, but it not work, and due to this memory not set perfectly in slot. Can you help me, i scare to press more, may be it will broke.
RAM modules in laptops are secured by spring clips on both sides of the RAM module.
To release the RAM module press the clips away from the RAM module and the RAM module will pop up at an angle. You can then pull the RAM module away from the memory slot.
Insert the RAM module in the slot, push it into th slot and then press the RAM module down until the clips on the side lock onto the RAM module.
Testimonial: "It s work. Thanks for help. Mayur"
SOURCE: install memory in Dell Latitude C640
http://support.dell.com/support/edocs/systems/latc640/sm_en/upgrades.htm#999869
this link would be helpful
SOURCE: SYSTEM DOESN'T RECOGNIZE NEW MEMORY MODULE
Memory modules must be the correct type and speed, and be within the specifications for the laptop. Just because it fits in the slot doesn't mean it will work.
The Dell inspiron B130 has 2 slots. Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot. if you tried to insert a 2GB module, it will not work.
If the module is within these parameters, remove and re-seat the memory, and try swapping the modules from one slot to the other. It may be a bad slot.
SOURCE: physical memory dump how do
you do not need a disk just hold down power but tell it turns off wate 30 second and then turn it back on
SOURCE: Dump of Physical Memory
Put the Dell CD in the drive bay. Turn on the computer and start pressing <F12> key. It should say "Preparing one-tome boot" When the screen shows a selection menu for the boot device, use the arrow keys to select the CD and press <Enter> key. That should run the Dell CD. Follow the onscreen prompts to run diagnostics checks
SOURCE: Dell 700m memory upgrade
No, it's not necessary. Verify the memory is compatible with the computer.
Bottom slot work great, but top slot not work, memory not fix in top slot/not proper connect..
