I printed a nozzel check pattern & segments were missing. I then cleaned the print heads. I still had missing segments. I was preparing to do another print head cleaning when I got the message to replace an ink cartridge. I replaced the ink cartridge, & waited for it to charge. I was preparing to do another check pattern when the printer stopped & I got the "Service required message." The printer stopped & will not do anything.
SOURCE: printing blank pages
hi-
You might be having a clogged nozzles, if you want you can try to dismantle and check on the nozzles, heres the link on how to check it just click HERE
Pls rate as fixya if it helps. Thanks!!
SOURCE: Printer Head cleaning
I've encountered the same situation with my 925. It requires routine cleaning. Try using name brand ink if you aren't already. Cheap ink has a tendancy to dry and clog at a quicker rate. Also, be sure to turn off the printer when you are finished with it. From what I understand, when you shut it off, it caps the ink nozzles like putting the lid on a ketchup bottle.
When doing a job with lots of ink usage, use a quality paper and do a nozzle cleaning right before hand. Hope this helps.
SOURCE: not printing - just replaced ink cartridges
Reseat the cartridges.
Do 3 consecutive head cleanings.
SOURCE: epson cx8400. I've put in new black ink cartridge,
For some cases the automatic head cleaning dosen't resolve blocked nozzle issues. For such you simply need to go manual; so please try the procedure below. If you are not at all a technical person get a brother, sister, husband, wife etc who is to help.
Ink may be new, but their nozzles may be blocked; depending
on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle
and press firmly. If the tissue comes off well blotted with ink it means you
still have a good amount of ink in it and the nozzle is not blocked. If not
blotted or scantily blotted, it means ink is really low or nozzle is blocked.
To be very sure of this, place nuzzle in a plate/saucer with a bit water so
that the nozzle is soaked. Leave for about 10 minutes. Then apply the tissue
again. If still not well blotted it means ink is really low or empty. If new
you should return it for a replacement. In the case of blocked nozzles, the
procedure may be repeated over to get results.
SOURCE: Epson Stylus CX5400 will not print. This printer
Did you use Epson Genuine Cartridges? ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!You might have dried it up.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
