Televison & Video Logo
Posted on Jun 04, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Screen black, no video have audio. Went black at some point when I was distracted. Have tried unplug/pause/repugnant - no help. On/off did nothing either.Vizio, Mdl- VO320E, LCD. Not listed on your schedule.
Back2life Electronics
Level 3:
  • Master 933 Answers
  • Posted on Jun 04, 2012
Master
Level 3:
Answers
933
Questions
6
Helped
274571
Points
2189
You need to perform the flashlight test. Turn off the lights in the room, turn the TV on, take a bright flashlight and shine it on the screen. Do you see the faint image on the screen?? You could have a defective backlight inverter, defective power supply, or a main board issue. You set will require diagnosis to determine.
5 Related Answers
Dewayne Turner
  • 87 Answers
  • Posted on Oct 23, 2007
SOURCE: Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
marionbagget
  • 718 Answers
  • Posted on Mar 07, 2009
SOURCE: 2004 Toshiba 37' LCD HDTV-No video only audio?
This problem is caused by at lease one of three conditions;
1) The inverter board(s) is bad.
2) The power supply for the inverter board is bad.
3) You have bad CCFT(s) (Cold Cathode Florescent Light)
Anonymous
  • 10 Answers
  • Posted on May 23, 2009
SOURCE: Vizio screen went off but power light is still on
may be a mainboard problem. If you can see the orange light it usualy means that there is power running through the TV... usually inverter boards are a problem when you do not see any backlight at all.
Anonymous
  • 10 Answers
SOURCE: VIZIO LCD VX20L, intermittant video/audio with Blue screen message "No Signal"
If the tuner is bad, changing the mainboard should fix the problem.
Anonymous
  • 6 Answers
  • Posted on Feb 23, 2010
SOURCE: Black screen but have audio.
It's a pretty common problem. (If this is a plasma your post says lcd but it came up under plasma.) The no picture but sound problem is usually the y sus board. I've replaced 2 on mine now. The 680uf 35V capacitors usually are bulging because one of the power transistors went and took them out. This has happened to both of the y boards I had. One time the failing y board took out the buffer boards too, and once it did not. The fix is super simple and anyone with even the most rudimentary knowledge of computers or electronics can do the labor yourself. You should do the simple stuff first by just doing a quick test with a multimeter. Just check the power coming to the y board. After that you can just remove the y board by removing 3 cables and like 3 screws. Plug in the new board and it's done! You can source the parts from a place like shopjimmy or discount merchant. 3 boards were like 200 bucks. 1 board is like 100 bucks. Labor took me 15min. Think about that the next time an electronics repair place charges you 1000 dollars. Of course they check everything (Yeah right) and warranty their work (I don't) but if you check the service manual it states that this is the most common repair. Look for the Canadian manual online. Hope this helps!
Our roku TV's screen picture abruptly cut out, just a black tv screen. Checked the cable connections, unplugged and re-plugged, restarted the tv with the factory reset button, tried using restart sequences...
It's possible that there could be an issue with the HDMI port affecting the display picture.
Try connecting you Roku device to a different HDMI port on the TV, and then playing content again.
Try using a different/new HDMI cable to connect your device to your TV.
Xdvd1262 video no signal
The most common is that the cable that activates the camera is touching ground and this activates the camera and has nothing connected as black screen looks
I was taking pictures, but paused for a moment to find a better angle. I guess I got distracted for a few minutes. I went back to the camera to see that the screen was black. I thought it had turned itself...
Hi. Yes, that happened to me once. Battery went dead and doesn't have enough power left to retract the lens. Camera worked fine after I put in charged battery. I hope this is your case too.
Aug 25, 2010 • Cameras
Black screen - audio works - hp logo on start - then goes black
It is either the power supply or the backlight inverter board finally failed. You will need to do some voltages checking inside, also see if you can see any bad caps in the power supply.
See my troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Parts: www.shopjimmy.com
Tv is black but i can still hear?
Check your wire connections on the back of the tv to make sure nothing had caused them to get unplugged OR been chewed through. If it doesn't fix the problem then try replacing your connections.
1helpful
Black screen and no sound on TV
what is the brand, model? try to be specific if you want be helped!!!
1helpful
Opening the display screen DCR SR47
the camcorder will stop recording automatically when the lcd screen is closed.
GV42L Vizio HDTV Problem
You didn't mention whether you have any audio; details like that can influence the response.
If you have audio but no visible video, look at the screen from an angle for 10-20 seconds to see if any video is present. If you do see some shifting shadows on the screen and have audio, the backlight or its power supply (inverter) has probably failed.
Screen zipped down to dot of light in center and went blank. No audio either
the deflection circuit shut down and i hope it didn't burn the crt's .
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
