I also have no heat when I turn that on, I had a leak in my cooling system but I stopped that, and now have new coolant in it. the first leak was a loose nut straight down from the Rad cap on the driver side, now when it runs and starts to over heat its starting to leak on the passenger side near the engine. is it the pump? Thermostat? please help
This leaking on the passenger side sounds like possibly the water pump. I THINK that this is a cross-mounted engine, with the drive belt on the passenger side. If so, it is almost certainly the water pump leaking. Get a flashlight and a small inspection mirror and search around under the water pump drive pulley for signs of water dripping. If no water is found there, it probably is not the pump. Have you checked the cooling fans for proper operation? Tested the temperature sender that controls the cooling fan?
water pump on this should be the bottom pulley closest to the front of the vehicle.Like tom said lay on the ground under it and look with a light.But just dont look for coolant you should be able to see the bearing vent hole on back side of pulley looking up at the pump if not wet look for staining or calcium build up on pump housing around vent hole.99% of the time this condition you describe is the water pump
