Goodman cple42-18
SOURCE: Capicator
Sounds like someone has replaced the origional split cap (fan,herm,common..not compressor) with two seperate units. The voltage doesnt really matter its the MFD rating that will need to be the same. The larger #mfd capacitor will be the compressor's and the smaller the fan motors' capacitor. Since it does have two seperate caps than the liklihood that they are your problem is slim i would look elsewhere.
SOURCE: hello i have a goodman ac u nit model#cple 30-c1
a click out side? at the t-stat? [email protected]
SOURCE: My Central air unit wont cool:
it my kick out on low pressure. low on freon or 410a . over the winter monthr if the service are not tru-blued or sealing compound the systen will leak out
SOURCE: where is the fuse/breaker on a goodman cple 18-1
Hi, I wanted to look up the numbers you gave me as you listed 2 different model numbers, the CPLE-18-1 is a 1&1/2 remote condenser and the other you showed CPLE-24-1 is a 2 ton unit. Doesn't matter, but if your power was lost you have your main breaker box at your meter, and at the condenser you will have a disconnect box with a pull out type plug. If you see no fuses, try removing the plastic cover as they are required to install 2-fuses in side the box also. If this is a split system with the outdoor and indoor unit, you will also have a breaker inside for the indoor unit, its high voltage and you will have a circuit board in the indoor unit with a 3 to 5 amp auto type plug in fuse.
I hope this has helped you out on this. I will be here if you have more questions. Please do not forget to rate me as I know you will be kind. Keep me posted.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contracted
