The speakers pop slightly when I plug the power cord into the wall so I know it's getting power but non of the lights are on and no sound will come from it. Nearby interference from a laptop connected to the system causes snow and popping the speakers (nothing new) but still no sound from the instruments or mics.
SOURCE: Samson Servo 170 - 1 dodgy channel
http://www.soundonsound.com/forum/showflat.php?Cat=&Number=403253&Main=351397
Posted on Dec 17, 2007
SOURCE: SETTING LEVELS ON MY POWER MIXER FOR MICING DRUM SET
Go check out these pictures, and there is some good info about micing up your drums. :) Recording it is then a case of getting levels good for a start by worling your way around the kit one drum at a time setting the level for that drum. a bit of nice reverb in the mix and out come you drums.... whoooohhooooo
Posted on May 13, 2008
SOURCE: Samson co1u recording issue
you first 3 people are idiots... maybe if you had worked with the hardware you would know how the mic works because its obvious you don't. The 4th person is correct because this is exactly how i use the mic and it captures sound in stereo format beautiful when set up rite. Using it in mono, whether use keep on one channel or two drastically reduces the crisp sound that this mic can record.
Posted on Jan 16, 2009
SOURCE: Samson C01U USB mic not working on my PC.
try this;
1.using different usb inputs on your pc desk top
2.update drivers on both your desk top and laptop
3.using a different usb cable
if it works fine on your friends computer most likely its not the mic
Posted on Feb 26, 2009
SOURCE: Playback only on left speaker
The quick, easy solution is to change your microphone to mono recording. In the attached YouTube clip, I'll show you how to do that.
The short and simple is to go to your Mac HD -> Applications -> Utilities -> Audio MIDI Setup. Select your C01U USB device, and set it to 1ch 16bit. This will set the microphone to record in mono, equally over both speakers.
Posted on Mar 09, 2010
Aug 10, 2014 | Ryobi Factory Reconditioned ZRRS290 2.6...
May 07, 2014 | Holmes Products HM495-UC Humidifier
Sep 29, 2013 | Televison & Video
Sep 17, 2012 | Sega Genesis Console
Apr 26, 2012 | Samson Servo 300 2-Channel Amplifier
Apr 04, 2012 | Televison & Video
Sep 05, 2011 | Yamaha RXA1000 Receiver
Sep 02, 2011 | Behringer Sx3242fx Eurodesk 32-channel...
Jul 29, 2011 | HP Officejet 5610 All-In-One InkJet...
Apr 30, 2011 | KEF Audio PSW 2150 Speaker
Mar 27, 2019 | Samson Audio Players & Recorders
75 people viewed this question
