SOURCE: Philips DVD LX3600D
just type in to google make-model of dvd player and region codes
and search for the one you want .
riz.
SOURCE: philips lx3600d
Common problem with the Philips - here is how to fix this issue:
There are a few possibilities.
1)You can connect a red and white AV cable (or the red and white portion of a red, white and yellow cable) from the TV Audio OUTPUT to the "Audio In/TV" portion of the HTS (NOTE: Many TV's do not have an Audio OUTPUT).
2)You can connect a red and white AV cable (or the red and white portion of a red, white and yellow cable) from the Audio OUTPUT of your cable or satellite box to the "Audio In/TV" portion of the HTS.
Note: Using a red and white cable may not give you sound on all 5 speakers.
3)Get a digital audio or SPDIF cable and run it from the TV, Cable or Satellite Box's Digital Audio OUT to the "DIGITAL IN" of the HTS. This will give you the best sound quality. When using this (or any of the other) type of connection, press SURR until you get sound from all 5 speakers.
Also, the manual can be obtained from www.usasupport.philips.com
-Tha Mp3 Doctor
SOURCE: Philips LX3600D Home theatre always returns to standby mode
There is a 1ohm resistor on the 4x4 pcb as soon as you take off the cover. ( I forget the ID # ) It supplys the -15volts to the control bd. The resistor will not looked burned. It was under rated. An ohm meter will find it ( open ). Rreplace it with a 1/3 watt. I believe the orig. was a 1/4 watt.
SOURCE: Connecting a computer to a LX3600D Home system
Lots of people are doing this and part depends on what your home theatre has to offer in the way of connections.
For sound most use the LINE OUT on a computer or laptop and connect that to a suitable input on the receiver using a 3.5mm to stereo phono lead.
If you are lucky enough to have an OPTICAL sound out on your computer and one on the home system that would be a better option.
For the video side again it depends on what your computer has to offer
If it has DVI and your TV or home system has DMI then that is the very best option. remember to lower the resolution on the computer first and to check and of your graphics card options for dual display. A DVI to HDMI lead is needed for that
Nvidia graphics cards seem to work best in this area.
If you have a VGA connector on your TV that is another great option and you would only need a VGA lead.
Some cards and laptops have S-VIDEO out. Lots of TV's and home systems have these and the display is quite reasonable. If using S-video connections use a GOOD quality cable.
Some people can only obtain a black and white picture so check your graphics card did not come with any special adaptor.
Another method is composite video Even that is not always 100%
Some laptops need a special S-video adaptor which is just a short little cable to properly enable the S-video and convert S-video to composite. That is probably the worst way to do it.
Using a VGA to component lead is also an option but results vary wildly from no picture to quite good. A lot depends on the quality of the lead once again.
I use the optical sound and DMI lead to power a 50" Sony with great sound and picture.
SOURCE: philips lx3600d dvd surround home theatre system dvd player fault
when the dvd is inserted it shows up no disc so it is not loading
