I have samsusng rv511, and it appeared operating system not found, i checked bios and it didnt list my hard drive so i bought new ssd ocz hard drive, i tried to install OS but it didnt supported. It keeps on saying that it cannot boot because of hardware.
Posted by laser_ravi on
General Systems Consulting
    Top Expert:
  • 5,051 Answers
Did you replace a SSD (Solid State Drive) with a SSD Drive? You have to replace the drive with the same type of interface that it had.
It sounds to me like there is a setting in your bios that needs to be set. Check for something like AHCI and see if it is set on something like SATA. If so change it.
I think your old drive is ok. Most times when the drive is bad the system will tell you and it's not the message that it can't find the operating system. Put you old drive back in and lets see if we can work through this.
Make sure when you boot that it is booting from your hard drive and not from a lan or from a music cd or movie video that is in the cd/dvd drive. There should be nothing in the cd/dvd drive when you boot. Watch the screen and see which key it says to press to change your boot order or boot sequence and hit that key. You have to hit that key when you see the message or it will not work and you will have to reboot. Select your hard drive as the boot device and lets see what happens. If you still get the Operating System Not Found message lets try to run the check disk utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Posted on Jun 04, 2012
5 Related Answers
digiteyes
  • 110 Answers
SOURCE: Bad Harddrive
Can you just clarify that you installed XP with the new IDE drive installed in the notebook and that you have selected disc 0 in the bios as IDE and that it is aslo set to boot from that drive?
What you are describing also fits the symptoms of installing XP on a SATA drive without installing SATA drivers first. (XP doesn't install SATA drivers, Vista does.)
So this does sound like a bios setting issue
Posted on Apr 11, 2008
rickyostrom
Ricky Ostrom
  • 274 Answers
SOURCE: thinkpad 390x 2626, won't boot from cd drive
Try pressing F12 at startup, you should get a boot option.
Posted on Nov 19, 2008
babygenius55
Edward Easley
  • 97 Answers
SOURCE: I am trying to install
I would first make sure that your laptop can actually handle the HDD's capacity, and the interface, then go into yout BIOS and make sure any switches that need to be hit are in fact set properly. First make sure that it is actually powering up. Regardless of what's going on, if the jumper settings are correct your motherboard should notify you that there is a proper conection in the bois display. If you don't see this, make sure that it is actually powering up, and that the jumper pin(s) are positioned correctly.
Posted on Jan 06, 2009
cpenzes
DEKR
  • 1102 Answers
SOURCE: hard drive will not boot, seen by bios but not seen by OS
if you can get into safemode
click start then run
type msconfig
in general tab click normal startup mode load all drivers etc.
then click okay or apply
restart and then if a box appears click do not show again
hope this helps if not let me know
Posted on Jan 22, 2009
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: Operating System not found PXE-E61 Media Test Failure IBM T42
Some BIOS allows for a hard drive diags. try it to test the hard drive, if ther is no such utility you need to test the hard drive anoter way.
Basically either the hard disk controller has failed or the hard drive is faulty. In most cases the hard drive is dead.
To check if the hard drive is OK, remove the hard drive and attach it to a USB hard drive adapter then plug it into a working computer's USB port. If the computer sees it as an external drive and you can view the contents of the external drive then the hard drive is OK.
Posted on Mar 22, 2009
Hello, can anyone explain the right process to move operating system to an SSD?
Some third-party migration software does work! Here I recommend free software AOMEI Partition Assistant Standard. It can move your Windows 10 to the new SSD easily and safely. You can boot from the SSD by changing the order in BIOS.Check the detailed guide following:
http://www.disk-partition.com/articles/transfer-os-to-ssd.html
Aug 28, 2017 | The Computers & Internet
What f key gets me into bios on my gateway 4860 desktop?
A quick Google search says its F1. I would try one at a time to find out, from F7 to F12. Some BIOS also show something when you press ESC. That being said, when you install a new and empty HD or SSD, it usually dont have boot sector and skips to the next device that would be the DVD or install media of the Operating system you are going to use. So you dont need to enter BIOS to reinstall the system. If its not booting, check your install media.
Oct 03, 2016 | Gateway Computers & Internet
I have a vaio nw150j with bad hard drive. What are the steps for ssd and new os install?
If you bought the same drive I don't see why you'd have to do anything to the Bios.
Apr 04, 2012 | Sony VAIO VGN-NW150J/S Notebook
How do i go about finding the fm station to get the audio?
Hello monron123028, go to this "Website."
You'll be able to "Download [PDF] Reference Guides, and Product Sheets.
That will give you the opportunity to gather more information at your leisure.
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
Click here: sata-ii-2-5-ssd.html">http://www.ocztechnology.com/ocz-onyx-series-sata-ii-2-5-ssd.html
Feb 17, 2011 | OCZ Technology Onyx Series 128 GB SATA II...
I was assembled a PC to edited video HD. This PC comprises: mothercard Supermicro X8DAH+, 24 GB of RAM, 2 X Xeon 5620, 1 X SSD OCZ Agility 2 3 X HDD Hitachi 1TB CD/DVD/BR LITEON ihbs112 GPU...
Remove the 3 hard drives and install Windows on the SSD. After successfully installing Windows you can add the hard drives and create your raid array later. Or even better, pick up a cheap RAID card so your CPU doesn't have to do all of the RAID controller work.
Dec 15, 2010 | SuperMicro X8DAH+F motherboard Intel 5520...
When my laptop boots up it says operating system not found
Not good. Check your bios for correct drive for boot up, but it sounds like yoru hard drive is not being read....
Oct 26, 2010 | Acer (ACERMOTHERBOARD)
Hello,,, I got a Dell Inspiron 910 Mini Laptop. As I boot it up there is a stop message and a driver comes up. And then NO OPERATING SYSTEM FOUND. What must I do? Help me Please...
would indicate that the operating system is not detected. try to restore or reinstall your OS, if this does not work, try to remove and reconnect the hard drive of the system which I believe is an SSD type. You can also try to run diagnostics by trying FN power button to turn it on or tap F12 when system is restarting and select Diagnostics from the One Time Boot Menu. It is possible that the SSD drive needs to be replaced
Sep 16, 2010 | Dell Inspiron 9100 Notebook
Cannot load operationing system because of fault saying, "no hard disk found in this computer"
Check the data cable. Make sure it is fully connected. (Sometimes they come loose). Check all connected data cable's & power cables within the system. Start with the new drive you installed. Unplug the data cable & re-connect. Follow it to the motherboard & do the same. If no cable seemed loose than replace the hard disk drive's cable with a new cable. Standard 80-conductor Ultra DMA IDE/ATA interface cable. See below;
ab2779a.jpg When you start up the dimension 4600, enter the bios, watch your screen at start up. You will need to press F2 or F10 key to enter the bios.
Once in the bios check that you hard disk drive is shown.
Most bios will list the drive by its model number. If you see the model number of the drive chances are you can save & exit the bios. Button up the case. You should be able to load windows.
Luck!
Mike
May 05, 2009 | Dell (E210882) Motherboard
Computers & Internet Logo
174 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
