Question about Tylo Pool & Spa
Hi, i just bought a second hand tylo typ 8e sauna heater with the wires cut off at the rear. It has 380/220 volt~8kW and AB EL-SPIRALER on the plate and 302 50 halmstad sweden also. I need to know wha
It is brown, got 3 bays at the top, 2 side ones with vents and the centre one with rocks. it is 45cm wide 57cm tall and 20cm deep. in the base there is a central hub with all the red and black wires going to it, and the stripped green wire goes to a seperate bolt (earth??) Then white wires go from the central hub to six points on the base of the elements (3 each side) and then 4 go to a small square box with a round red button (fuse???)
Posted by maffmay on
  • maffmay
    maffmay Jun 03, 2012
    hi, i really need to know what unit it is and how i can get in installation manual on it and if i need a seperate controller on it or not? i am in australia too. please help?
5 Related Answers
Jrussell789
  • 172 Answers
SOURCE: 3 wire cook top to a 4 wire outlet
Older 3 wire connectors where Wht=Neutral Ground Return, Red=One Phase Hot, Blk=Second Phase Hot, of 220VAC stove connections.
Newer Electrical code standard has a forth wire that is bare copper for a separate safety ground return.
I suggest you but a 4 wire pig tail cable for your stove top, available at Depot or Lowes, and connect 3 wires of this 4 wire cable just like the 3 wires are now connected. The 4th bare copper safety is attached to any metal part of the stove. Find a screw you can loosen to wrap it around and tighten.
Posted on Mar 02, 2009
Anonymous
  • 290 Answers
SOURCE: needing wiring diagram for 1991 dodge dynasty le
here is what I found:
http://www.the12volt.com/installbay/stereodetail/715.html
Posted on Mar 26, 2009
erpaalai
Eric Duda
  • 999 Answers
SOURCE: wiring a 220v single phase motor and capacitor
Black and white are usually power. an ohmmeter will confirm. Brown are for capacitors. There is almost always a diagram on the motor someplace. Eric
Posted on Jun 17, 2009
Anonymous
  • 139 Answers
SOURCE: need help wiring a max-e-therm heater.
red wire is other leg for 240.use whit ,black and green
Posted on Jul 12, 2009
Anonymous
  • 9 Answers
SOURCE: heater only gets mild warm Tylo sport 4 heater
more than likley installation problem not enough voltage top operate heating element
Posted on Feb 01, 2010
Wiring diagram for tylo ts30 single phase
Swell... Anonamous,
Take your "patience" issues to the
company (Tylo)
where they might be considered constructive...
It's just a 'TUDE here ...!!
(not helpful)
Control Panel TS (USA)
Carnac the Magnificent
Aug 23, 2014 | Tylo Deluxe 11kW Sauna Heater, w/ TS30-01...
Where is the safety shutoff on a Tylo super sport 7
On top of the unit/sauna, you will need to remove the roof or wood covering. It is held down with screws, usually. If your unit in fact does have a reset it will be located on the side of the control box which is located on top of the sauna.
Jan 15, 2013 | Tylo Super Sport 7 Sauna Heater
My tylo supersport 8 sauna no longer produces heat. The timer works but there is no heat. I have checked the circuit breaker but that doesn't appear to be the problem. Any thoughts??
Remove the unit bottom panel (2 small screws) and look at the quick disconnect terminals on the heater rods ( 6 heating rods - 3 on each side of the unit). If you have any corrosion on these terminals, the wires will overheat and fail, preventing the heating rods from working. If the wires did overheat, you should see melted wire insulation. Replace bad wire and quick disconnect terminals with new. Should cost less than $20.
Nov 23, 2010 | Tylo SUPER SPORT-U8 Sauna Heater 8 kW
My name is Andy Smith i am Electrical Engineer on
Hi Andy, I am Kelly and wish to at least make an attempt to help you out. I have done quite a bit of research and like you have come up with little nothing positive.
You may have to buy your own 3 phase 24DC controlled contactor and control that with a yet another relay.
At this point you may want to call Tylo direct or email them and explain your needs to see if they can help you.
Page 8 of their installtion manual shows several 3 Phase connections
http://superiorsaunas.com/storeimages/products/heaters/tylo/tylo_elec_install.pdf
Tylo contct info:
TYLö AB, Svarvaregatan 6, S-30250 Halmstad, Sweden.
Tel +46 35 10 00 80, Fax +46 35 102580. E-mail: [email protected] Internet: www.tylo.se
Here is the controller you may need with a 5 meter capillary tube. it does not say if it is 3 Phase and it is mecanical.
Seriously I would contact Typo directly via the contact info above and solve your problem quickly.
The link.... for the TS-30-012
http://www.saunahaus.com/Sauna-Control-Units/Sauna-control-TYLOe/TYLOe-Control-panel-TS-30-012::218.html
I do wish you the best.
Jan 26, 2010 | Tylo TS30-01 Control Panel
Heater only gets mild warm Tylo sport 4 heater
Jan 23, 2010 | Tylo SPORT-U2 Sauna Heater 2 kW
Pool & Spa Logo
74 people viewed this question
Top Tylo Pool & Spa Experts
john h
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Are you a Tylo Pool and Spa Expert? Answer questions, earn points and help others
