I am trying to connect a HP DESKJET 3050A ALL-IN-ONE j611 to an Eee PC notebook
Install the printer driver and connect the printer to your notebook using the USB printer cable.
You can download the HP printer drivers from their supportWEB site. Please click on this link and select your model printer to download:-http://welcome.hp.com/country/us/en/support.html
SOURCE: ASUS EEE PC 900 wireless lan doesn't appear on network connection
please if u have a switch for the wifi connection on your laptop please put it on and should see the wifi on your taskbar also please check in controll panel then go to my network connections and see the wifi resides there if yes just right click and enable if not ther check device manager and check for nework devices if the wifi is enable and installed ...if not please installed by right clicking on it and using reinstall..
please let me know what happens
thanks
SOURCE: Eee PC 900 has problem with wireless connection
try to change the password to wpa personal in router and then try it on lappy
SOURCE: eee PC 1000H/XP - my wireless connection stopped functioning
1) Try to check your connections. Follow the guide from Microsoft, here: http://support.microsoft.com/kb/314067
2) You could try reseting your TCP/IP stack. Try this:
When you run the reset
command, it rewrites two registry keys that are used by TCP/IP. This
has the same result as removing and reinstalling the protocol. The reset command rewrites the following two registry keys:
SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\
SYSTEM\CurrentControlSet\Services\DHCP\Parameters\
SOURCE: i got eee pc 900a but wireless not working i try
If that still doesn't work, make sure you have the drivers you need from here:
http://support.asus.com/download/Download.aspx?SLanguage=en-us
