Marantz SR-7000 Receiver Logo
Question about Marantz SR-7000 Receiver
Configuring Marantz for digital input analog output
I have HDMI input from cable and computer to a Vizio internet TV. I have a digital optical (toslink) out of the Vizio TV to a Marantz SR 7000. Output from the Marantz needs to be analog. Previously the output from the Marantz was digital. how do i make this configuration change on the Marantz?
    Top Expert:
  • Marantz Master
  • 76,851 Answers
Refer its user manual for details.
Posted on Jun 03, 2012
5 Related Answers
Anonymous
  • 682 Answers
SOURCE: Marantz SR-5200 - Analog inputs only play the right channel
please invert your cable and watch if the problem moved the problem in your cable change it with new one.from any radio shack near you or any electronic store.
Posted on Jul 05, 2008
Anonymous
  • 565 Answers
SOURCE: I have the following hardware:
Remove the HDMI cable (out) to the speakers from the receiver.
Connect regular speaker wire from the receiver to the speakers.
Of course, remove the (now extra) HDMI cable from the tv.
That will remove the loop.
Posted on Jan 25, 2009
lauriejb2006
  • 127 Answers
SOURCE: I can only get audio, but no visual, when
I think you may have the wrong idea about this unit. It only receives sound. It isn't a television tuner.
Posted on Dec 01, 2009
Anonymous
  • 3 Answers
SOURCE: my Marantz sr 4001 receiver has no output. Is
my friend has the same problem with an SR 4001. the tech said it was an internal fuse soldered to the board. the display showed an error code that clued in the tech of the problem. I am trying to find the fuse on the board, and trying to get a value(Volts-amps) of the fuse
Posted on Jul 28, 2010
Anonymous
  • 961 Answers
SOURCE: no image, only sound when
Whatever video components you have, they should be, depending on inputs on TV, should be run to TV first. Recievers do have pass through ports but, are not the best way to achieve picture and sound. HDMI cables are great but you r reciever may not be able to transfer the video. What I suggest is taht you run your componenets, cable/sat box, DVD, etc. via HDMI, componenet, etc., to TV input, then, run audio out from TV, via(best) digital optical. You can use TV's menu to choose what you watch while, you only have the one input to reciever. Scan your recievers menu to make sure you have selected the proper mode(TV, Aux, Vid2, etc.).. If you run your video unit to TV with component cables, you will have to get your sound through separate cable(s). Component cables have graet video, but do not carry the sound.
Posted on Jun 14, 2011
Manual says only audio inputs are output to the rca audio outputs. How can I get digital audio inputs to output to where I can connect wireless speakers.
Does your receiver have a set of rca connectors labeled "tape out" or "tape monitor" those might work as a better output. As far as the delay goes, if you have your tv hooked up via hdmi, then you will not be able to get the audio to sync up with it. the tv takes longer to decode and display an hdmi output than your receiver does for an audio input.
How to hook up the TV
To use the TV as a Monitor: Use an HDMI cable from the Monitor Out on the 6006 to an HDMI Input on the TV. You need to go into the setup menu and set the HDMI sound to go to the amp and not the TV.
If you are tuning TV stations with an antenna and the TV tuner: First connect the TV as above so you can watch your other sources, like Blu-ray players. Then add an Optical Digital Audio cable from the output on the TV to an optical input on the TV. When watching antenna TV, select the input on the 6006 that the optical cable is connected to. You may have to play with settings in the TV and the 6006 to get this to work! You should be able to listen to 5.1 sound while watching tv over the antenna.
1helpful
Connect with componet cables.
The only digital audio input for this TV will be via the HDMI input. Of course, even with HDMI in, you're only going to get a simple stereo output from the TV. You can use the analog L & R audio inputs for a very similar sound from the TV speakers.
The digital multi-channel audio (Dolby Digital, THX, 5.1, 7.1, etc) encoded in the program should be connected to a suitable multi-channel amplifier with either a TOSLINK (optical), RF (coaxial) or HDMI cable for theatre-like sound. This can be done by (a) cabling from the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) directly to a multi-channel amp and speakers, or (b) from the HDMI output of these devices (DVD, BluRay Disk, Set Top TV Tuner, etc.) into one or both of the TV's HDMI inputs. This will provide only stereo sound output from the TV speakers. You should connect the TV's TOSLINK optical "Digital Output" jack with an optical cable to the amplifier's TOSLINK optical input jack to obtain theatre sound.
To listen to the program shown, you would select the amplifier input assciated with the optical, RF or HDMI input that is connected to the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) if connected directly. If the TV HDMI input(s) are used, they are output to the TV optical output and should be connected to the amplifier optical input. The amp input associated with the optical input should be selected to hear the program with theatre-like sound.
No optical output except when using ipod dock on tv
Unfortunately, there is a limitation on the JVC LT47P789 digital optical audio out. This audio output does not get the signal from any HDMI source. This is described on page 49 of the user manual. The manual is available from JVC here: http://resources.jvc.com/Resources/00/01/14/YA653ien.pdf . There is a similar restriction for the analog audio output from the TV with the HDMI inputs.
If you use the component audio/video inputs on the TV from your set-top cable box and DVD player, then the optical audio output will work. Otherwise, you need to find a way to connect the audio directly to the receiver. Some receivers have multiple HDMI input ports. These then forward the video signal on their HDMI output to the TV. Another option is to connect the analog audio outputs from the cable box and DVD player to the receiver. This may require resetting the Audio output from these set-top boxes to keep from sending the audio over the HDMI cable. With the Cinemate, you might need some sort of audio input switch or an HDMI converter and switch that separates the audio from the video signal.
I hope this helps. Please add a comment with more information about your devices for ideas on how to work-around the problem with this JVC TV.
2answers
I have audio cables going from HD 61g887 jvc tv, to my phillips surround sound system under aux but it is not giving me sound?
hi
you didn't mentioned the model number of your surround sound system, for a better solution its important. any why try the following.
if you are connected the analog audio output of your tv to the system using RCA cable, then go to the setup of the surround sound system and change the input assignment setting from digital to analog.
If your connected the digital output of your tv to the digital input of your surround system using optical cable then, goto the setup of your surround system and change the input assignment to digital (optical) input.
if u need any further assistance fell free to contact through fixya
1helpful
No analog comming out of receiver when optical input is used .
as a rule...in order to get analog audio out of a receiver, it must have an analog input. you could use a digital to analog converter between the tv and stereo or come out of both of your source devices (ps3, cable) with analog to the receiver. good luck
1helpful
Connect home theatre to 32" lcd to ps3
Depending on the year of your model of VIZIO your digital optical output may be tied to the DTV input only. Meaning the only time you will have audio coming out of the digital optical output is when your using the tuner and your on a digital channel. If your television is newer and the digital optical output is in white on the back of the television than it is tied to HDMI and the DTV Tuner and you will pass audio through the digital optical output when using HDMI or the Digital Tuner.
Now to get connect the HT: Normally you would run a digital optical cable from the source device to the home theatre system. Meaning if it was a PS3 you would run a optical cable from the Digital Out on the back of the PS3 to the Digital In on the Home Theatre receiver. If it was a DVD player than you would run the optical cable from the DVD player to the HT receiver. If you have a newer VIZIO and the optical output is in white and not black than you can run HDMI from the PS3 to the VIZIO and then run a optical cable from the VIZIO to the Home theater receiver.
You will have to adjust the audio setting in the PS3 to run audio out of the HDMI port if it is set to run audio out of the Digital Out or AV out. Also, if your going to run audio from the PS3 to the HT receiver through the Digital Out then you need to change the audio setting in the PS3 to Digital Out.
1. Select (Sound Settings) under (Settings) in the home menu.
2. Select [Audio Output Settings].
3. Select the input connector on the audio device.
Channel numbers and audio formats that are supported vary depending on the connector in use. AV is 2 ch. only, Digital Out is 2 ch. & 5.1 ch, and HDMI is upto 7.1.
5helpful
2answers
No sound from xbox to stereo using an optical out from TV to amp
If Im reading this right what you need to do
is hook the audio from the xbox to the stereo system
not to the tv .
5answers
Surround help
Hmm. let me see if I get U correctly. you use u'r theater system with a TV and the audio is fed via optical or U have DVD player that you can feed the audio via optical or coax. I think it is the later, if it is U could be having trouble with sound decoding setting of the DVD player itself. It's like mpeg out or PCM out instead of full DTS or 5.1 dolby digital decoding. If this is the case just use u'r dvd remote and check the audio play back settings. If this does not solve u'r problem, pls state u'r set up briefly, so tht I can understand the type of connection u use. Happy troubleshooting Rifaa
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
