SOURCE: power problem - Polaroid FLM 2601
i just repaired mine by replacing the 2 electrolitic caps that had a bulge on the top. they were 1000uf at 35 volts---works again!!!!
SOURCE: Polaroid FLM-2601 Power
First off replacing the caps is not easy even for a tech. Double surface boards are soldered on both sides. The caps have a value printed on them like 1000@63 They also have polarity " they have to be put in in a certain direction" If you do something wrong you blow the works. Best to have it done by a tech.
SOURCE: how to access the inside of flm-2601
First- unplug it, Second- remove the back( can be tricky), Third- follow the AC cord to the power supply board and your there. Look for any Caps that may be bulged and replace them. Sometimes caps can be bad and look ok. Let ame know how you do>
SOURCE: Polaroid FLM 2601 flat panel TV won't turn on
Power supply board is dead.Replaced the power supply board.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Try Vance Baldwin a parts dist in florida
the handle Polaroid tv's
