Panasonic Lumix DMC-F1S / DMC-F1K Digital Camera Logo
A
Anonymous Posted on Jun 02, 2012
Panasonic Lumix DMC-FH20 screen has gone black and won't take pictures. What should I do?
5 Related Answers
  • 102366 Answers
  • Posted on Dec 06, 2010
SOURCE: dont have panasonic lumix dmc fh20 cd rom software
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras/Drivers-Downloads/model.DMC-FH20A.DS#ts
Anonymous
  • 214 Answers
  • Posted on May 25, 2011
SOURCE: Panasonic Lumix DMC - FH20
Hi could you post the sample picture? I am certain that it is circuit fail or white balance selection. Thanks and best regard!
ZJLimited
ZJ Limited
  • 17989 Answers
  • Posted on Jun 22, 2011
SOURCE: Panasonic Lumix DMC-FH20 shows "SYSTEM ERROR
Sounds like the Focus and Optical Image Stabilization drive motors are bound or broken. To fix this wrong will need disasemble the lens unit, focousing unit to do service; if needs, replace the damaged parts and assemble to run normally. Don't do this if your camera is under warranty.
Or, unless there are no marks on the case and they wouldn't think that it had been dropped or gotten wet, well you know, Panasonic will normaly repair or replace it as long as it is due to manufacture defect.
Hope this helps.
Anonymous
  • 43501 Answers
  • Posted on Jun 25, 2011
SOURCE: how to upload pictures from
Here is a tip that I wrote about how to find the manuals, drivers, downloads andsupport for Digital Cameras.
DigitalCamera Manuals, Drivers, Downloads, and Support How to easilydownload Pictures from Digital Camera
heatman101
Anonymous
  • 6831 Answers
  • Posted on Aug 15, 2011
SOURCE: Panasonic Lumix DMC -FH20 lens
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
1helpful
Lumix dmc-sz7
Use the Copy command in the Playback menu. See page 137 of the advanced manual:
http://service.us.panasonic.com/OPERMANPDF/DMCZS7_ADV.PDF
I need a driver for mu Panasonic Lumix DMC-FH20
Do you really need a driver?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
My lumix camera will come on, but the display for the pifture is black, how do i fix this
I think most of these questions about black LCD's and black pictures relate to a stuck shutter. My Lumix LX2 has this. The screen is black and so are the pictures. On looking at the shutter through a magnifying glass I took a shot and I saw that the iris works fine, but the shutter did not open. I am sending the camera for repair at a reasonable rate from Clearer images here in the UK.This is the email: [email protected]. Time will tell won't it?
Need instruction manual fo lumixfh20 camera
Visit this link to download your Panasonic Lumix DMC-FH20 (FS30) Digital Compact Camera User's Manual.
Hope this helps (remember to rating ans leave some comment about this free answer).
Oct 05, 2011 • Cameras
How to upload pictures from panasonic lumix dmc-fh20
heatman101
Panasonic Lumix DMC - FH20 Outdoor pictures have a blue tint to them. Why? and how can I get rid of this?
My Panasonic Lumix DMC TZ3 has two small scratches on the centre of the lens. Can it be repaired and is it cost effective? Otherwise the camera functions perfectly. Is it better to purchase a later model?
hi does it affect to picture? If it big scratch, it will. But most of case it won't affect on your picture. However it does, try magic black ink on scratch.( non gloss black ink) it will help a lot. Thanks and best regard! If you really want to change, your local repair shop would charge around $85 to 135 depend on what they really want to charge.
2helpful
Dont have panasonic lumix dmc fh20 cd rom software where can i get one
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
