Question about Hotpoint Ultima WF865 Front Load Washer
Hotpiontwf865 saying test
Displaying test
Posted by Angela king on
prem mathew
  • Hotpoint Master
  • 662 Answers
Press the "on" and "start" buttons together for 5 seconds. Don`t forget to give me an excellent rating.
Posted on Jun 24, 2012
  • prem mathew Jun 27, 2012
    Or wait until the screen shows: `d off ` or `demo off`
How to clear codes
i found this in another place
Quick Test Mode
Note: This test erases all faults and memory:
To enter press Spin, Soil, & Power
simultaneously with the power off.
1. All LED's light up and the washer beeps as it
enters the Quick Test Mode.
2. The unit displays the software version for a
second then clears the EEprom.
3. After the displaying the software version, LCD
will display Model information.
If EEEE is displayed the PCB assembly is defective.
For production up to 03/31/2009 Serial **S3**
4. When the version is displayed. Press the following
keys to test the various components.
Effective 4/1/2009 Serial **S4 ** a change was
made.
4. After the displaying the software version, turn
the Jog dial CCW to display "F4". Press the following
Press Temp Key to cycle through the Water Valves in
this order: Cold Main, Bleach, Cold Main & Bleach for
Fabric Softener, Hot, then off.
Press Spin Key to test Motor circuit.
Press Signal Key to test Drain Pump
Press Soil to test door lock - unlock circuit
Mar 03, 2015 | Samsung WF218ANW 4.0 cu. ft. High...
Displaying only 2 secs
Monitor STFC (Self Test Feature Check)
* Turn off the monitor
* Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
* Unplug the monitor video cable from the back of the computer
* Turn on the monitor
* The floating dialog box should appear on screen against a black background. If the issue appears during the STFC, the monitor is defective. Get it replaced.
Oct 31, 2013 | BenQ Computers & Internet
No disply p5vd2-x
Hello, If there is no display, then follow this steps to troubleshoot it, As it been displaying before and suddenly stops displaying, if your answer is yes then start with 1 check whether there is power to the board i.e power gets to the motherboard 2 Check the cmos battery,whether it is still ok, you can find the cmos battery on the motherboard 3 Check the RAM or memory whether it is firmly connected to its slot and working good 4Check whether your VGA chip on the motherboard is good if not you have to get an external VGA card and plug it on one of the slot either PCI or AGP slot. 5Check the data cable to the monitor, if it is still good,by removing it and testing it a good one. 6Check if the problem is not with your monitor either CRT or LCD by testing with a good one. If the motherboard is a new one and is not displaying , i would recommend you return it and collec a new one regards
Nov 26, 2010 | ASUS P5VD2-X Motherboard
My nokia 1108 is displaying test mode. it is not workin plz help
The "test mode" thing appears when we are installing the software on the cellphone. So there can also be a problem with the phone's hardware as well.
Oct 18, 2010 | Nokia 1108 Cellular Phone
HP color laser jet printer is displaying error 59.co on the display pannel
The "developing disengaging motor" has problems. You need a technician. Try running the component test from the control panel. Select the disengaging motor and test it. Maybe it'll start working after the test!
Mar 25, 2010 | HP LaserJet 4700 Printer
Ford fiesta 04 car not displaying milage when ignition on , car,
sounds like the car needs to have keys/car coded.does it turn over but not fire?...
Feb 26, 2010 | 1993 Ford Festiva
When switch on n70 displaying Test mode
service auto start problem: services diabaled problem appeared on my n70
Oct 02, 2008 | Nokia N70 Cellular Phone
FT02 is displaying
When mine said FT-02 it wasn't flashing or anything, but I pressed the cancel button and after it said "initializing" for a sec it went back to normal. FT-02 is some kinda test mode for the manufacturer, I think.
Mar 30, 2008 | Panasonic DVD-RV32 DVD Player
Hotpoint Ultima WF865 Front Load Washer Logo
52 people viewed this question
Top Hotpoint Washing Machines Experts
James Hehling
James Hehling
Level 1 Expert
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
