Sounds like there's an issue with your fuses, you'll probably need to buy a full fuse set for your matiz. if not check that all the cables are in tact and that nothing is disconnected.
Are daewoo matiz o3 central locking
SOURCE: Fuse location for clock & cigarette lighter???
check under the driver side dashbord the fuses are in there...
SOURCE: window wiper on a daewoo matiz
Buy wipers at a good national brand auto parts store and they will change them for you.
SOURCE: Daewoo Matiz crankshaft pulley
remove the outer small bolts to remove balancer(pulley) the big centre bolt holds crankshaft gear for timming belt which slides off with timming belt removed.
