SOURCE: Acer 19 " LCD Computer monitor
By initiating the on screen menu, you navigate to the brihghtness etc.This can also be related to contrast. Get a keyboard with zoom keys that will make it east to enlarge text.Mine is a logitech wireless S510 and its a great bargain and comes with mouse.the best solution is, however to buy a 42 inch or larger display and use that as you monitor. I can never go back!
SOURCE: Adjusting Brightness on Acer 17 inch monitor
you change the settings manually using the up and down arrow buttons or plus or minus buttons mounted on the front of your monitor you dont need to use mouse.
SOURCE: Hello how to adjust brightness on an ACER 19
1. Press the MENU key.
2. Press the < or > key to select the BRIGHTNESS icon from the menu (looks like a little sun).
3. Press the MENU button again to enter the BRIGHTNESS menu.
4. Use < or > to select appropriate brightness.
5. Press MENU button to exit.
5. To exit - select the EXIT function from the menu and press MENU button again.
SOURCE: how to adjust monitor screen brightness?
hi. turn on the tv and then use the remote. click on the menu and scan thru til you find picture brightness or picture quality. J.
