Question about Digidesign Mbox 2 Barebone
Only one guitar in and one mic in, there should be 6
In the mix window when I open I/O in only show one guitar in and one mic in, isn't it supposed to show 2 digital in AND 2 line in AND 2 mic in? how can i fix the problem. I do see them beneith guitar in and mic in but they are grayed and when I click them it says the output could not be made active because the output path is currently not available
Posted by jankeizer49 on
Michael Green
  • 3,799 Answers
They will only work when something is plugged into them.
Posted on Jun 04, 2012
Rockband 3 guitar for rock band
put new battiers in the mic and the guitar
Dec 30, 2012 | Nintendo Rock Band for Wii
Guitar will not play through amp the amp is working
This could be caused by multiple different things. The most common one is that your input cable is broken. The input cable which you are using is old or has been stored in a way that may have damaged the wiring inside. This would cause a weaker signal or none at all and could stop working. What I'd suggest is to find a friends input cable or test a different one out at a music store through an amp to find out if it is (or isn't) the cable. If it was the cable, then buy a new cable and toss the old one. If it isn't the cable that stopped working you may be forced to open up the back and re-install the wiring and the jack-in. In most cases, it would be advised for you to take the guitar to a guitar tech in your area and pay for them to fix it because it's a very long process where experience is needed in soldering circuits in order to avoid hurting the guitar. Other-wise, if you decided to fix it yourself you will need a soldering gun, flux, new electronics (depending on what isn't working. It could be the pickups, the jack-in, old wiring inside, etc.) and a lot of spare time. You will be forced to solder the connection between the pickups, the knobs that control bass/treble/mid/volume (etc.) and the new electronics. In order to do this, you must first heat up the circuit, then melt the flux and connect the new circuit quickly to flux before it oxidizes (to be simplified).
Jun 18, 2011 | Audio Players & Recorders
I just bought a fender passport 150 and it isn't very loud and the channel lights aren't even coming on when I plug in my guitar or my mic. You can hear the guitar and mic but only when the volume...
Turn down the VIP knob and try it. This is on channel 1 for announcement voice overs overriding everything. It has a threshhold setting for adjusting that. Here is the manual for it.
http://support.fender.com/manuals/pro_audio/Passport_P150_manual.pdf
Jun 05, 2011 | Fender Passport 150 Pro 150-Watt Class-D...
Yamaha Mg12-4fx 12-Channel Mixer
ok look here on page 21 & 22 of 32 http://www2.yamaha.co.jp/manual/pdf/pa/english/mixers/mg12_4fxe.pdf
section #5," ST output"
the "st out" will go to the amp you have for the mixed sounds
section #1, "line or mic input"
this is the input for the guitar or a mic , but only one(mic or line ) per input # at a time
Mar 31, 2009 | Yamaha Mg12-4fx 12-Channel Mixer with...
Installation
First you must determine if the mic's output from the receiver is low or high impedence. Tip: high imp. is usually a 1/4" jack , low imp. is a 3 pin XLR Conector. It also depends on your amplifier input jacks.But really you should connect the mic to a mixing console and then connect the console to the amp.But you could connect a high imp. mic via a 1/4" to 1/4",cable into the 1/4" jack on your guitar amp.
Mar 23, 2009 | Naxa Electronics NX984 Professional...
Guitar amp shows power but has no sound, could it be a blown fuse
Nine times out of ten, any problem with an amp having no sound coming out, it's a wiring issue. Make sure all of the wires internal to the amp are propely hooked up. Also, try switching out the quarter inch cord you are using from your guitar to your amp. Could be a bad cable. Unless you have blown the speaker completely, something is loose or not hooked up properly.
Feb 27, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Im using a mic, but its looking for a guitar, how do I get it to find my mic
It shows a guitar for higher input level or you can set it to a lower level(more sensitive) - it will then show a microphone
Dec 21, 2007 | ElectroVoice RE2-410 Professional...
Digidesign Mbox  2 Barebone Logo
49 people viewed this question
Top Digidesign Computers & Internet Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
matt
matt
Are you a Digidesign Computer and Internet Expert? Answer questions, earn points and help others
