Error E10/E12/E14: Main cause: The main motor (M1)(M2)(M19) is faulty. The DC controller PCB is faulty.Mode of detection:0000 The clock pulse do not arrive for 2 secs or more after the main motor drive signal
For more help you can check the canon iR6000 service manual from below link: http://goo.gl/yhuA4J
Error E354 in Canon iR 2016 error e354 code appear when you replace PCB controller board. Please note. Before replace your PCB board with other one. Pull out a small (FRAM COUNTER) chip from your old PCB board you can found it right side of the PCB board near a battery cell the chip attached with screw open screw and pull it out and attached it with your new PCB board .install your PCB board in the machine and turn on power error e354 will go off.
1 needs a new potential control sensor and pcb. this needs to be installed by a certified tech, However it can be the laser that needs replaced. The procedure isnt fun, this is a difficult problem to resolve.
2. this just needs a new thermistor sensor for the fixing unit. that part shouldnt cost more than 15 bucks. If fixing unit is worn past its life it should be replaced.
Hi, enter 10871087 on keyboard of machine, then enter 163.After that press "execute" and start button.machine will restart and will be ready to copy.Otherwise,call service.
