Question about Samsung RB2155SH Bottom Freezer Refrigerator
Help My Samsung SRS599HNW KEEPS BEEPING EVERY 3 MINS OR SO. THE FRIDGE IS COLD AND SO IS THE FREEZER BUT THE TEMP ON THE DIGITAL DISPLAY IS NOT GOING DOWN ITS DRIVING ME MAD
Posted by AMANDA ROSS on
5 Related Answers
Anonymous
SOURCE: samsung american fridge sn 188742bp100124K
The freezer temperature ok.
The fridge keeps freezing
Posted on Feb 26, 2008
Anonymous
SOURCE: Samsung RS2556 - Refrigerator side is not cooling - Freezer is fine
Ok, what I found out is that there are codes built into the front panel. If you hold the top left and right buttons for 5 seconds, the fridge will reset. If there are no issues, the panel goes blank. If there is a dash in the right side of the panel, there is an issue with the fridge side. In the left, freezer side. The dash indicates a defrost problem. Only a couple of things can cause this. 1. Sensor 2. Heater 3. Fan, 4. control board.
Posted on Jul 02, 2008
Anonymous
SOURCE: Samsung Fridge can't get temp down
it is probably the door switch. I just pulled the switch from a rb2055 and disassembled the switch. one of the contacts is broken.
If you unplug the fridge and plug it back in, the light should work. push in on the switch button with the door open. If the light does not go out, switch is bad.
pry the switch gently out with screwdriver, unplug it and get a replacement.
If you are watching this I can also probably tell you how to jerry-rig it to run while waiting for replacement swicth.
Posted on Jan 03, 2009
Anonymous
  • 67 Answers
SOURCE: samsung fridge freezer not cold enough
Heya,
I did samsung warranty for awhile and these fridges have a faulty defrost termination clixon. What happens is when you turn off the fridge it turns it off defrost. If you do get a tech out there are two parts you need to fix it. One is a yellow sensor cable and the other is a defrost termination wire that is black and red. These two parts i use to sell for $70aus when the fridges where out of warrenty.
I actually have one of these fridges now and work so if you have any other problems please let me know
Regards Mat
Posted on Jan 08, 2009
Anonymous
  • 700 Answers
SOURCE: flashing temp on freezer door
take and press the two top buttons on the control panel and reset the unit. it appears the the freezer is not operating properly and may by frozen up
Posted on Mar 23, 2009
Hey my Samsung cooltech plus is making beeping noises fridge temperature is jumping from one temperature to another while the beeping noise is going on. Can anyone please help me thank you
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
http://www.appliancerepair.net/refrigerator-repair-1.html
Refrigeration System Basics Chapter 1 Cause of Beeping Noise in Frigidaire Refrigerator eHow
Feb 14, 2017 | Samsung Refrigerators
E240B Fridge Freezer door open alarm goes even when door closed.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Dec 22, 2016 | Fisher Refrigerators
My s2655df fridge freezer is not working correctly,!the freezer and fridge don't seem to be no were near cold enough,,the freezer keeps flashing (on the screen were temp is displayed),(it flashes this _._...
I would say if this was a manual model, that it was your defrost timer. When you get a computer board involved, I'm just not sure.
Have you tried partselect.com ?
Feb 02, 2015 | Refrigerators
Fridge is making a beeping sound. The digital indicator for fridge area is saying Hi
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 17, 2011 | Frigidaire FRS3R5EMB Side by Side...
Our fridge is making a beeping sound every 2 to 3 minutes. how do we get it to stop????? door seems to be tightly closed. just installed a new filter. freezer feels cold but the gage says its only 39*......
those have a high temp warning,, anytime the freezer or fridge goes above a set temp it will beep,,, make sure all or the doors are shutting good and the gasket is sealing,, if they are try to find any cold air coming out,, if all is good,, you need to get a service tech because it could be a bad fan, or a bad sensor
Jan 24, 2011 | Samsung 24.8 Cu. Ft. Side-by-Side...
Refrigerator wont cool
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Feb 01, 2010 | Refrigerators
Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Feb 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Side by side fridge freezer
Based on your weird display issues I'd lean toward the control board problem. At least that can be "one" of a couple problems...
Feb 01, 2007 | Samsung RS2578BB Side by Side Refrigerator
Samsung RB2155SH Bottom Freezer Refrigerator Logo
187 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Michael Thomas
Michael Thomas
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
