Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Konical minolta bizhub 164 mahine service call c2558
kadhafi786
    New Friend:
Machine trouble sevice call [c2558] wat a problam in konica minolta bizhub 164 printer
Posted on Feb 02, 2013
5 Related Answers
Anonymous
SOURCE: Konical Minolta 2430 dl Streaking
Try cleaning the rollers.  Directions can be found starting on page 83 "Maintaining the printer" here:
http://www.kn.nl/data/handleiding/174952/user%20guide_engels.pdf
Posted on Jun 14, 2009
Anonymous
SOURCE: machine trouble call service c0500
Try to power it up with the STOP button pressed.
If not call service team.
Posted on Oct 10, 2009
taminol
taminol
  • 62 Answers
SOURCE: minolta bizhub erorr codeco202
CO202 relates to tray 1 (top tray). It hasn't managed to lift the paper successfully.
Open the tray, remove the paper, reset the machine (open/shut front door) then reload the paper and try again
Hope that helps
Regards
Taminol
Posted on Jul 27, 2009
xeerie
Zaheer Ahmed
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
hamzaskilltd
amir hamza
  • 318 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
How to clear c2558 in bizhub 164
High Toner concentration ratio.
Replace the Developer.
Jul 25, 2016 | Konica Minolta bizhub Office Equipment &...
Konica minolta bizhub 164 have Trouble service code c2558
Code: C2558
Description:
Abnormally high T/C ratio
- The T/C ratios detected by the TCR sensor board (TCRSB) are above the threshold for the detection of abnormally high T/C ratio for three successive times.
- The connector between TCRSB to PRCC is disconnected
Remedy:
1 Check to see if developer is available.
2 Check the connector between TCRSBrelay CN14-PRCB CN10 for proper connection and correct as necessary.
3 Change TCRSB. 4 Execute "TCR AUTO ADJUST. 5 Change PRCB.
http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Konica-Minolta&model=bizhub%20164&code=C2558
Jun 03, 2015 | Konica Minolta bizhub Office Equipment &...
Bizhub 184 164
Replace the developer in order to get rid of this problem!
Mar 12, 2014 | Office Equipment & Supplies
Error code c2558 in konica Minolta bizhub 164
help me my konico minolta bizhub 184/164 error (C2558) my mail id [email protected]
Sep 30, 2013 | Office Equipment & Supplies
Konica minolta bizhub 164 have a service code c2558
I recommend that you will post your question under the correct category (Printers) it will be easier for Experts to understand the question and answer it.
Jul 11, 2012 | Sport & Outdoor - Others
CARA RESET M2 BIZHUB 164
bagaimana cara reset bizhub 164 error c2558 mohon penjelasannya
Jun 28, 2012 | Office Equipment & Supplies
Minolta bizhub 164 error code C2558..how can I solve
my mail id - [email protected]
Mar 06, 2012 | Konica Minolta bizhub Office Equipment &...
How do I clear error message C-2558 for the Konica Minolta bizhub C253
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Nov 12, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
1,158 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
