Could not get kindle fire to charge. I bought a new charger and still wotn charge. Port needs to be replaced. Is it possible to replace just the port?
We repair these A LOT! The jack is unbalanced on the Main Board and is easily detached by normal wear and tear. Soldering the jack back on to the board is a little tricky but the real repair is getting the port sturdy to prevent the issue from re-occurring.
We do a full repair by removing the old solder on the board and the jack then reattach using flux and fresh solder. We also stabilize the port so it doesn't happen again.
You can send it from anywhere in the US and we'll repair it for $39.95 which includes return shipping. I strongly recommend replacing the micro usb / charging port for an additional 9.95
www rockhoptec com
please call or email with any questions!
(585) 487-8220
alex @ rockhoptec com :)
SOURCE: 8300 will not charge
My charge port is broken out of my 8300. I bought an extra battery and an external charger off of eBay for a little of nothing. You can also by a pod that will charge your Blackberry. The two gold tabs on the back of your device beneath the battery is an external charger connection for a desktop pod.
SOURCE: Palm Treo 650 charging port loose and will not charge
I had this on mine, it seems to be a wear and tear issue, mine has gone back to Palm for a paid repair as it is out of warranty:-(
Kevan
SOURCE: My kindle will not charge. I plug it in and there
If you've explored all options with software settings and If you're outof warranty, you can try to open the kindle and replace the battery.There is a Kindle Repair Guide that shows you how to take it apat. There are services that can do it for you. Kindle Repair.
SOURCE: can't charge sidekick lx cauz da charger port is ruin inside
buy a universal charger its like $20
SOURCE: samsung SGH E840 won't charge with charger
I just have the same issue and unfortunately I can see the phone's plug it's messed up. I can see a pin inside came of the connector and it's pushed all the way in the back. Used original Samsung charger only!!<!-- from fixya rte -->
