Question about Hisense Televison & Video
Red light on my hisense tv keep blinking and the tv wont come on
Posted by NANNIE STARKE on
SD Tech
    Top Expert:
  • Hisense Master
  • 14,553 Answers
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.red light on my hisense tv keep blinking and the t - 6_2_2012_2_03_27_pm.jpg
If any or all of this information is beyond you then consider the set is in shutdown as something is wrong===likely in the power supply of the set which is where most of these problems happen.
Posted on Jun 02, 2012
5 Related Answers
kodi319
SOURCE: red blinking light
The red light blibking 6 times indicates that the power supply board has a defective or damaged area. I know this because i had the same problem...bought a damaged tv for parts and replaced the power supply board as the tv would not turn on...wokrs like a charm now.
Posted on Dec 03, 2008
Anonymous
SOURCE: tvs red light under lamp keeps blinking and it wont turn on
There was a firmware update from Sony for power up & down problems for the KDFE42A10 among other models which were made in July 2005. If you go to the Sony website (service/support) you can find a link where you can enter your model # and serial # to see if your TV is affected.
The update takes an authorized service guy to come to you home and load the new firmware from a USB memory stick. It takes approx 5 minutes to do. Mine has worked flawlessly for three years now and it was Sony who contacted me to do the update within the first few months I owned the TV.
You should have this done if your TV is affected. Sony indicated that power on and power off problems could begin after six months or so if the update is not done. Sounds like it may be the same issue unless your lamp is bad.
Also, if you have recently had the lamp door open for any reason, you need to ensure it is closed and locked correctly or the lamp light will flash three times in red and won't allow the TV to start up.
This is all covered in the manual under the Troubleshooting' section and is also referred to in the first few pages of the manual where the LED are explained.
Good luck !
Donnieboy - fellow Sony 3 LCD owner
Posted on Oct 21, 2008
Anonymous
  • 1077 Answers
SOURCE: the tv red light keeps
Try leaving it unplugged for an hour so it can reset itself.
If it still has the problem, it may need a new power supply inverter board. That's what happen to mine.
Posted on Feb 18, 2009
Kenneth Lee Sr.
  • 597 Answers
SOURCE: my sharp aquos not working tv went off and wont
these flashing lights are error codes set by the manufacturer..
Call sharp...they will tell you the problem
Posted on Apr 26, 2010
Anonymous
  • 4090 Answers
SOURCE: Hisense tv turns on and off
STOP!
The unit has a fault on its power board and sustain board.
It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
Please rate my help++++Thanks for using FIXYA
Posted on May 13, 2010
Have Hisense tv that keeps resting itself red light blinks four times and rests itself again over and over. I have replaced main board still does it.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Hisense led lcd tv m no. 32k20DW s. n.32J135216H06497 power on light blinks then stays red i have sound, no picture.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
My 42' hisense tv turns on then blinks. blue then
Take it to a servicer with proof of purchase or back to the store. You will get it repaired for free or get a new TV.
1helpful
Tv won't turn on
Jus wait a little and tv will just start by itself.
Televison & Video Logo
Top Hisense Televison & Video Experts
Jean Sintulaire
Ekse
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
