Question about HP PSC 2410 All-In-One InkJet Printer
Can't print on colored paper
I'm trying to scan from a book onto colored paper for a learning Bingo game. I've been able to get it to scan & print on two random sheets (one a dark blue, one a bright yellow) but have had problems repeatedly even with those. From taking too many sheets of paper, saying there's no paper (most frequent problem), to pushing the ink cartrige too far to the side. Most often it sounds like it's printing, but only a blank sheet comes out after taking much longer than it ought to.
Posted by Daniel Eastman on
5 Related Answers
Anonymous
  • 944 Answers
SOURCE: How do I scan colored paper and still read print? HP Scanjet 8270
First thing to try is just play with all the scan settings to see what gives you the best result - try changing resolutions, type of document, type of output document, contrast, brightness, type of scan. If this doesn't give you any better results, then one of the best ways to do this is to get some plastic sheet of the same or almost the same as the predominant colour on your forms (you can go one step further and make a multi coloured filter if you are feeling creative and your forms are all identical). The text jumps out of the page and most scanners will give you a good scan - just make sure the filter is not too thick/dark. Hope this helps :)
Posted on Jun 25, 2007
kehalim
Michael Lugassy
  • 55 Answers
SOURCE: why do all pages print onto one page when i hit the print button in a multipage document
I guess you are using word. In that case the default driver you use and comes standard with windows is flawed. Download a new one from HP.
Posted on Oct 24, 2007
Anonymous
  • 70 Answers
SOURCE: printing is printing blank sheet of paper
Lots of reasons here but usually it is because the software you are using to print is not compatible with the operating system anymore. Example: you used MS Photo Editor which was discontinued in 2003 and never supported under Windows XP. The one function that is broken is printing...it looks like it printed but a blank sheet of paper comes out. (exactly what you described)
Instead, use MS Picture and Fax Viewer or the follow-on product, MS Office Picture Manager.
If you remove the MS Photo Editor application under Control Panel/Software Programs then your picture files will open with a different (more print compatible and friendly) program.
Posted on Jun 21, 2008
bandana_gyrl
Sarah McDonald
  • 181 Answers
SOURCE: try to print mapquest directions and sends blank sheet out
Internet printing can be tricky because everything is in HTML which is not designed for printing but for clicking. So there are links and features but when you try to print it can be blank or half pages. Is there a button on the site that says printable view or print these directions or something similar? If you click on that it should allow you to print the page as you see it on your screen.
Posted on Jan 29, 2009
Anonymous
  • 8 Answers
SOURCE: Extra blank sheet of paper between printed pages
Check your print settings, it is possible that you enable page seporator in the settings.
Posted on Apr 30, 2009
How do I get my HP Desktop Printer 3050A to scan full 8.5''x11''?
Hi Joe,
Do do not select Paper type or Paper size for Scanning. Set the preferences to Auto or Default and Scan it.
Regards,
Sean
Apr 09, 2013 | HP Deskjet 3050A J611G Inkjet...
I've got 2 Kyocera 5030's that are smearing color copies
if the toner can be wiped off of the paper then your issue is the media settings or the fuser is failing. If the image is fixed onto the paper but just "looks" smeared then it could be the drum(s), transfer belt, color registration, or cleaning system.
Mar 25, 2013 | Kyocera Office Equipment & Supplies
Printing Issue, "Out Of Paper" message
Try to unplug the power of your printer for about 30 seconds then plug it back in.
Also, make sure that the firmware of your printer is up to date. Just go to http://bit.ly/ghfW8H to download the firmware update.
Sep 27, 2012 | Lexmark Impact S305 Wireless All-in-One...
FUJI XEROX CM205fw can't set custom paper size
So I am not the only one encountering the same problem! Printing A4 & DL are great but it simply does not let me print A6 properly no matter how hard I tried to configure the paper size (at the printer settings, printer preferences, the application settings etc)
Can Fuji Xerox fix this?
Apr 26, 2012 | Office Equipment & Supplies
Brother HL-4040CDN Laser Color Printer Printing Quality Issues
Hey Robb, Laster printers don't have print heads dummy, that is for inkjets. Just close your mouth if you don't know anything.
Dec 03, 2011 | Brother HL Office Equipment & Supplies
My color picture is coming out black and white. I can't figure out how to fix that. I've scanned color pictures before...
You might be selected print in grey scale only.
Go the printer properties> printing preferences >color remove check mark then try it..
Sep 14, 2011 | HP OfficeJet 4215 All-In-One InkJet...
I have a Canon MP210 scanner/ printer that is telling me I have a paper jam but there is no paper in the machine. I've turned off the power and turned it back on, I've looked for a small piece of...
Your printer might be out of paper.. so try this..... press Black/Color button... if it doesn't work turn off your printer and press paper feeder on the back side and press the power button with holding the paper feeder. Don release it until the process of printer is complete... thanks
Aug 26, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Colors and photos do not look right when printing on glossy paper using the HP Z6100PS large format printer. With photos on glossy paper, the ink seems to reflect off the paper, making the photos have a...
Hi
Did you try to calibrate on the same media what you want to print?
Try to delete any other calibrations stored. And re-calibrate the plotter on the same media or a plain paper.
DO RATE MY SOLUTION
Jul 07, 2011 | HP Designjet Z6100 InkJet Printer
How do you scan an image onto the computer using the Canon MP190 series? Ive tried hitting scan and it only tried to copy the image and print onto paper.
Place the paper you wish to scan on top of scanner.
1. Go to window start manu.
2. Find picture board.
3. Click the file manu at picture board, and find the scanner.
4. Click the scanner and it will scan the paper as soon as you click ok...
5. After completion of scan, click "save as" and name the title wish to make.
That's all...
Apr 21, 2011 | Canon PIXMA MP190 All-In-One InkJet...
HP PSC 2410 All-In-One InkJet Printer Logo
56 people viewed this question
Ekse
efs_perpends
efs_perpends
