Question about Sharp AF-S120FX Air Conditioner
Air Conditioner Problem
Air Conditioner keep tripping E01 code after the filter is clean and the reset button is reset
Posted by Albert Smith on
vikas verma
  • 504 Answers
Check for input supply voltage
Posted on Jun 02, 2012
1 Related Answer
MoishePippik
  • 23 Answers
SOURCE: reset air conditioner
Unplug it. Wait a few minutes. Hold in the Power button while plugging it back in and keep the button held down until a beep is heard (~5 sec). Unplug the air conditioner, then plug it in again.
Note: some units require using the Mode switch, rather than Power.
Posted on Jun 15, 2008
What does the E1 mean on the display
I read that this is a filter problem. There may be more than one. Turn it off and clean the filter. For many window air conditioners this code is simply a reminder to clean the air filter. After like 750 hours of run time this code pops up and you have to clean the filter and then reset the unit before it will work again. To reset the code you need to simply unplug the unit and then plug it back in again. On other units you need to hold down the power button while you reenergize the air conditioner.
On another make of window air conditioner you need to push the "fan" button twice and then the "mode" button once to reset this code. Still another person found that the circuit boards where going bad and they had to replace them to get the unit to work.
Jun 08, 2014 | Amana ACD105E 10000 BTU ENERGY STAR ROOM...
Tip
How to Reset Your Air Conditioner Filter Light
<span style="font-weight: bold;">Cabin Air Conditioner:</span><br /> <ol> <li>Press and hold down the Off button for 4 seconds.</li></ol><span style="font-weight: bold;">Carrier Air Conditioner:</span><br /> <ol> <li>Press the Reset Filter button to reset the timer that calculates the next air filter change after you have inspected / cleaned the indoor return air filter.</li></ol><span style="font-weight: bold;">Daikan Air Conditioner:</span><br /> <ol> <li>Press the Filter Clean Reset button to reset the CLEAN FILTER INDICATOR after you have inspected / cleaned the indoor return air filter.</li></ol><span style="font-weight: bold;">Frigidaire Air Conditioner:</span><br /> <ol> <li>To reset after cleaning the filter, press the "Filter Reset" button and the light will go off.</li></ol><span style="font-weight: bold;">GE Air Conditioner:</span><br /> <ol> <li>Turn the air conditioner OFF and unplug it.</li> <li>The air conditioner must be unplugged for the automatic filter clean timer to reset. Clean the filter.</li> <li>After cleaning, replace the filter and plug the air conditioner back in.</li></ol><span style="font-weight: bold;">Honeywell Air Conditioner:</span> <ol> <li>Press and hold the i button until the timer is displayed, followed by pressing the Up Arrow button (next to the Wake button)</li> <li>Press the Run Program button.</li></ol><span style="font-weight: bold;">Kenmore Air Conditioner:</span><br /> <ol> <li>To reset the filter indicator, press and hold the filter reset button for 3 seconds.</li></ol><span style="font-weight: bold;">Lexus Air Conditioner:</span><br /> <ol> <li>Without having foot on the brake, press the Start button twice to get to the IG-ON position.</li> <li>Then press and hold the "hard" OFF button next to the "hard" Auto button. Hold the OFF button for approx 5 seconds and you hear several beeps.</li></ol>or<br /> <ol> <li>Turn the engine switch to IG-ON mode.</li> <li>Push and hold the A/C OFF button for more than 4 seconds.</li></ol><span style="font-weight: bold;">Lexus 2008 Air Conditioner:</span> <ol> <li>Push the "INFO" button & touch "Maintenance".</li> <li>Touch the desired button Delete All: To cancel all conditions which have been input or Reset All: To reset the item which has satisfied a condition. If "ON" is selected, the system gives maintenance information with the "Information" screen when the system is turned on. If "OFF" is selected, the "Information" screen is disabled.</li> <li>Input the Notice of Date: The next maintenance date must be input.</li> <li>Now input the Notice of Distance: The driving distance until the next maintenance check.</li> <li>Delete: To cancel the date and distance conditions.</li> <li>Reset: To reset the date and distance conditions.</li> <li>Touch "OK" The screen returns to the "Maintenance screen.</li></ol><span style="font-weight: bold;">Lincoln LS 2001 Air Conditioner:</span><br /> <ol> <li>Press and hold the setup button above the radio until it says system check. NOTE: All the doors must be closed.</li> <li>Watch the system check when it goes to A/C filter hit the reset button.</li> <li>Hold down the reset button to confirm.</li></ol><span style="font-weight: bold;">Lincoln LS 2003 Air Conditioner:</span><br /> <ol> <li>Press the STATUS control to access the System Check function, the message center will display A/C FILTER XX% RESET FOR NEW.</li> <li>Press and hold the RESET control to set to 100%.</li></ol><span style="font-weight: bold;">Lincoln LS 2005 Air Conditioner:</span><br /> <ol> <li>Insert the key and turn the ignition to "Run" or "On." It is not necessary to start the engine.</li> <li>Press the "Status" button above the radio until the system display changes to "AC Filter."</li> <li>Press and hold "Reset" above the radio. The system will beep and the "AC Filter" display resets to "100%."</li></ol><span style="font-weight: bold;">Maytag Air Conditioner:</span><br /> <ol> <li>Press the "Fan" button 2 times, then press the "Mode" button 1 time and it will reset.</li></ol><span style="font-weight: bold;">Whirlpool Air Conditioner:</span><br /> <ol> <li>Push in the filter reset on the remote using a straightened out paper clip or similar.</li></ol>or<br /> <ol> <li>On the control panel, press and hold the Mode and the Up Temp Arrow buttons for 6 seconds.</li></ol>or<br /> <ol> <li>After having cleaned the filter just press the reset button located on the indoor unit behind the front panel to interrupt the flashing of the filter monitor indicator.</li></ol>
on Jun 17, 2011 | Heating & Cooling
When I push reset button all lights come on for about 2 seconds and trips reset breaker in plug.
Hi chip faust - When was the last time the filter was clean? Restricted air flow from dirty air filter can caused air conditioner to turn on and off rapidly. Make sure there is nothing blocking the airflow to the unit like drapes, blinds, furniture, etc which could restrict air distribution. When was the last time you cleaned the outside condenser coils? Confirm that the condenser coil is clean and not restricted by any trees, bushes, etc. Verify that the plug is not damaged and try resetting the unit. If any of these suggestions prove to be ineffective, then the unit could possibly have faulty PC power board, faulty compressor or power supply. Connect with a professional to accurately pinpoint any potentially more serious issues.
Jan 23, 2013 | Frigidaire FAH106N1 Wall/Window Air...
What to do to fix the E1 error on a haier her08xc7
Push buttons about five times each beforjust to make sure they are not stuck....then......Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset. Clean the filter. See the Care and Cleaning section in your use and care manual. After cleaning, replace the filter and plug the air conditioner back in.
Other forums say the E1 code is because the AC thinks a button is stuck or because it's dirty, but almost all of them say to use the remote and it'll work ok.
Jul 23, 2012 | Haier HWR08XC7 Air Conditioner
E1 error code
E1-Automatic filter clean reminder.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Aug 07, 2011 | Haier HWR06XC7 Air Conditioner
Turning off code e1 flashing what is e1 code
Jul 28, 2011 | Sharp Comfort Touch AF-R120EX Air...
We have an E1 code on our Sharp energy star model AF-S100FX air conditioner and the unit will shut off. What does the E1 code mean?
Display Codes:
Jul 22, 2011 | Sharp AF-S100FX Comfort Touch Air...
We have a portable air conditioner. It keeps
Follow the steps below....
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
Jun 26, 2010 | Heating & Cooling
My r7184P, I have to keep pressing the reset button for it to work. Changed filter, and cleaned fuel line.
The reset button may be tripping because of air flow restriction.. The filter may be dirty or the evaporator coil may be clogged if this is the case you need to clean the coil with a coil cleaner available at home improvement stores. It also could be the bi-metal in the swith itself has gone bad in that case the cord needs to be replaced. The cord problem happens when there has been an electrical storm or a heavy power surge. Its not often but it does occur.
Good Luck on your repairs
Dave
Aug 30, 2009 | Whirlpool ACC108PS Air Conditioner
It turns off
The e1 code is a demand to clean the filter. It means the unit has been running for 720 hours. It does not mean anything is broken...unless it hasn't been running for 720 hours. That would mean the "clean the filter" timer is broken! There are 2 reset methods.
1) Unplug the machine. Hold down the power button while plugging it back in and wait until it beeps (for about 5 seconds). Let go of the power button. Unplug the machine again, then plug it in and try to use it as an air conditioner.
2) Unplug the machine. Hold down the Mode button while plugging it back in. Keep the mode button pressed until it beeps (for about 3 seconds). Let go of the mode button. The machine will start. Turn it off by pressing the power button. Resume trying to use it as an air conditioner.
If neither of these work, the "clean the filter" timer is broken and needs replacing.
Jul 23, 2008 | Sharp AF-S100FX Comfort Touch Air...
Sharp AF-S120FX Air Conditioner Logo
99 people viewed this question
Top Sharp Heating & Cooling Experts
Colin Stickland
Colin Stickland
Dennis Boxerman
Sheldon Dedek
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
