Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Need to disable dhcp on a konica minolta bizhub
I need to disable dhcp on this machine, which is not on the network (so I can't do it from a computer). How do I navigate to this option on the printer itself?
Posted by Nathan on
Zaheer Ahmed
    President:
  • Konica Minolta Expert
  • 347 Answers
1-Press "Utility/counter" button on basic panel of your printer.
2-Press "Administrator settings"
3-Press "Admin-2"
4-Press "Network Settings"
5-Press "IP settings"
6-From this menu you can disable/enable network settings.DNS Settings, DHCP, Auto, manual, etc all network settings are in this menu
Posted on Jun 03, 2012
5 Related Answers
Anonymous
  • 8 Answers
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
Anonymous
  • 6 Answers
SOURCE: printer is offline
go to Start... click Run .... type services.msc and find print spooler right click stop and click start again
Posted on Jul 16, 2009
SOURCE: The printer has stopped functioning all together.
C3851: Abnormal Low Temp. (Heater)
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Posted on Sep 03, 2009
Testimonial: "This is exactly what I needed to do to fix this error. I got it fixed a long time ago but this is the correct answer!!!"
Anonymous
SOURCE: machine trouble call service c0500
Try to power it up with the STOP button pressed.
If not call service team.
Posted on Oct 10, 2009
xeerie
Zaheer Ahmed
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
How can I download driver for Konica Minolta bizhub C-252 on windows XP and direct to unit with ethernet cable?
Robert, C-252 Copier prefers that you give it a IP address (Call Static IP) Do not use DHCP which the network determines .
Go Administrator, Admin One Network TCP/IP have your network administrator determine best IP address for your network.to give the copier
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 17, 2014 | Konica Minolta bizhub Office Equipment &...
Disable color on bizhub c654
Self Help Product Support Konica Minolta Business Solutions Inc
Try this site down load the op manual get the info you need.
Feb 06, 2013 | Genuine Konica Minolta Konica Minolta...
Reset password bizhub 211
how can i reset the password for my konica minolta bizhub 211 to remove the maintainance call 2 display?
Nov 21, 2012 | Konica Minolta KONICA BRAND TN-211 BLACK...
We have a Konica Minolta bizhub 250 All-In-One Laser Printer and somehow we disabled the network connection and now the printer doesn't allow any connection to it through the network cable even if
When the copier is on the network does the little leds flash at the network connection? ping the ip address of the copier what do you get.
Go into admin mode on the copier network setting what is your ip address, subnet and gateway reading did you replace a router? now the network is one system and the copier was never told this new info?
Jan 01, 2018 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta Bizhub 200 - We changed out our router and now our networked printer wont work on any of the machines! I need help
You need to add the printer to your new network, just as you did your PC's
Click on start, all programmes, contol panel, networks. (This is for XP, Vista & win7 may be slightly different).
You'll also have to make nominate it as a network shared resource as you're adding it.
Mar 08, 2011 | Konica Minolta Bizhub-200 Minolta Printer
Missing network tab on konica minolta c250
1st try restarting the Bizhub. Use the switch located behind the front panel, not the switch to the right of the operation panel.
If that is unsuccessful, try setting the Bizhub to DHCP (use the administrator mode under utility/counter at the machine), then back to a fixed IP.
Aug 05, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta Bizhub c252 network problem
firqst: DHCP disabled
copier IP adress should be 192.168.x.y
IP Pc must be 192.168.x .z (169.254.xx.xxx is a bad address!! = No-IP address !!)
see my recommendation for the scan on a previous post (http://www.fixya.com/support/t1395654-konica_c252_scanning_address_book_job)
Oct 09, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
669 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
