Televison & Video Logo
Question about Samsung Televison & Video
My samsung crt tv 10 yrs old goes blank after working for some minutes making a cracking sound.it shows picture occasionally.any solution!
Posted by akindeled660 on
    Top Expert:
  • Samsung Master
  • 76,849 Answers
EHT arcing takes place inside the TV. Clean the circuit board and inside components. You can use vaccum suction pump. Take care.
Posted on Jun 02, 2012
5 Related Answers
Anonymous
  • 54 Answers
SOURCE: tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Posted on Apr 16, 2008
Anonymous
SOURCE: JVC 27" CRT TV AV-27BP3 display shows single horizontal line
I have a similar problem on my CRT computer monitor (AcerView 76c). It is an old screen and I think it is just at the end of its life, much like your TV. Having some background in physics, I would be pretty sure that the problem is with the cathode ray tube's vertical deflection system. The horizontal deflection electrodes are working while the vertical one is not. This results in a display of a single horizontal line (or in my case, a few superimposed) in the centre of the screen. Where both X and Y (horizontal and vertical) deflectors fail then the electron gun firing would result in a single bright spot in the dead-centre of the screen.
So really, we have no choice but to move on and buy a new set as repair is probably just as, if not more, expensive than replacement with a new device. Seeing as your post was in 2007, I hope you managed to solve the problem.
Best wishes,
SZ (Sydney, AUS)
Posted on Oct 05, 2008
kberl73
  • 4 Answers
SOURCE: Sony projector kp53hs10
I recently had this same issue. If you remove the speaker pannel in front of the set, you will see a block with 6 knobs on it, just to the right of the center panel. This is called a focus block. 3 knobs on top which control the voltage going to each tube, and 3 on the bottom are for fine tuning focus for each tube.
If your problem is the same as mine, it is a convergence problem. and due to the fact that the picture is turning off, says that one of the tubes is not getting enough power.
NOTE: BE CAREFUL NOT TO TOUCH ANYTHING ELSE BUT THE FOCUS BLOCK, THERE IS EXTREMELY HIGH VOLTAGE WITHIN THE TELEVISION, AND CAN CAUSE SERIOUS INJURY.
1. Make sure the screen is blank, ex video 2 with nothing on. It's easier to tell.
2. very slowly, one at a time turn up the knob on the left top, should control red, untill you start to see lines come on the screen, then turn back just till they dissappear, and you see a black screen again.
3. continue with the second knob on top, just the same as the first.
4. And continue with the 3rd knob on top right just the same.
5. when you're finished, turn off the set, then back on, let is set for a min or 2, then hit the FLASH FOCUS.
If the problem persists, it most likely is a IC chip.
Best of Luck
Ken
Posted on Dec 03, 2008
Anonymous
  • 21 Answers
SOURCE: Panasonic Quintrex 32" 100Hz CRT
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Posted on Sep 18, 2009
Anonymous
  • 77 Answers
SOURCE: power up the tv after about 10 - 15 minutes
If this is CRT TV, you need to change the LOT(line output transformer) to fix this issue. This issue is due to overage of the television.
Posted on Sep 06, 2010
1helpful
My sony wea lcd 60 inch television goes blank with no sound every 5 minutes or so for about 30 to 45 seconds then the picture and sound come back the set is just over 3 years old
Symptom shows TV needs new lamp and existing lamp is getting weak / dying.
Replace lamp in TV and procedure is written in user manual.
Let me know model number of TV if you need user manual copy.
Thanks.
2answers
After about ten minutes the picture goes blank but
It sounds like the main board may have went on the TV. It should be not that costly to replace
Screen goes blank for seconds
bad connection, soldering goes old .using soldering iron, locate bad connection and redo them agin
Samsung T.V. goes on for 30 seconds then no picture
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
1helpful
Horinzontal white line with sound
vertical collapse. usually not to expensive to fix.
2helpful
2answers
Tv screen goes black
Picture reduced to a horizontal line across center
sounds like the vertical, more info ctechnicians.com
Marvin
Marvin
