Question about Berkel 827E Gravity Feed Deli Meat Slicer
How to remove berkel slicer blade - Berkel 827E Gravity Feed Deli Meat Slicer
Posted by emserv2003 on
veigacamilo
    New Friend:
My berkel slicer model 818 the motor runs and the automatic table will slid but the blade does not torn
Posted on Jun 13, 2012
5 Related Answers
Anonymous
SOURCE: Can we use common mineral oil to lubercate a
Mineral oil is safe to use. You NEVER NEVER want to use any type of vegetable oil or pan spray. It will do more damage than good to your slicer. The good food machine oils are a just a high quality mineral oil.
Posted on Mar 22, 2011
Frank Lipsky
  • 195 Answers
SOURCE: need a parts manual for Berkel 825E slicer
Hi I have four (4) different one's I will try to attached them here for you
it won't let me attache dbut here is th eaddress good luck , if you need parts get back to me i have serveal parts for each type of slicer
http://www.retrevo.com/d/ds/progress?doc=1096457ae4ac5b3050fb47ab5d5835a6&u=1&rk=0.12324874425124166
Posted on Dec 13, 2011
Peter Hampton
  • 193 Answers
SOURCE: The blade on this berkel 827e bogs down to a stop
most times the belt fill slip if you overload it and no they don't have oil holes
Posted on Apr 28, 2010
Fred Yearian
  • 5603 Answers
SOURCE: BERKEL 825 THIS IS NOT
It s NOT uncommon to have new parts be slightly different than old version of the part and require slightly different hookup. The part number you have included does NOT appear to be a rocker switch.
I do see a rocker switch part number "823-00039-1 SWITCH, ROCKER" that may be what you need if it is a rocker type. The part number you gave is a "toggle" type with a "bat handle".
I suspect the problem is they gave you the wrong part.
Posted on Jan 04, 2011
Anonymous
  • 20 Answers
SOURCE: Berkel 827 sharpener not working properly
Your grinding stone stud is more than likely frozen try and lossen it up with a little penetrating oil take the sharpener off and work both stone back and forth untill they are both spinnig freely and remember do not apply either sharpening wheel on the knife for more than 5 seconds at a time you can burn the wheel and then it will never get sharp
Posted on Jun 13, 2009
Can't sharpen blade
1 of 2 problem exist, you need new stones, or the depth of your sharpener needs to be lowered to compensate for blade wear
Mar 27, 2012 | Berkel 827E Gravity Feed Deli Meat Slicer
We have a meat slicer with no manual and no brand name anywhere on it! The only information on it is a plate at the back that says "MATR 32, TYPE 220M" My husband can't figure out how to...
Hi if he has to remove it , never heard of someone removing a blade to clean it , he needs to use a inpact screw driver with a hamer, I see so many louse fingers not knowing what they are doing
Oct 02, 2011 | Berkel 827E Gravity Feed Deli Meat Slicer
Do not have model #...older slicer. need to remove blade to clean behind
there is a thru bolt on the left side of the slicer if you are facing it to use it, that holds the plate on, unscrew it, its usually red
Sep 07, 2011 | Berkel 827E Gravity Feed Deli Meat Slicer
What tool do i need to remove the blade from my Berkel 827A?
Just a screw driver, but first remove the thru bolt holding the blade cover, its on the left side opposite blade its red, take it off then you will see the 4 screws, ez
Jul 13, 2011 | Berkel 827E Gravity Feed Deli Meat Slicer
Guard
I'm not certain this is the same model I'm thinking of, but I think there may be a knob on the back side (behind the blade) which clamps down on a shaft coming off the blade guard. Loosen the know and the guard should pull straight off. Maybe I'm thinking of a different model slicer, but the photo looks correct.
May 19, 2010 | Berkel 827E Gravity Feed Deli Meat Slicer
Sharpen berkel slicer blade
collee; take the blades to a machine shop or a small engine shop they will be able to sharpen them.
Dec 21, 2009 | Sewing Machines
Feb 03, 2009 | Berkel 827E Gravity Feed Deli Meat Slicer
Globe Meat Slicer Model # 500 motor runs blade not turning
Fiber gear on blade hub stripped. deep socket required to remove hub. DON'T CUT YOURSELF!! remove motor, used food safe solvent to clean grease out of housing. Fiber gear held on with snap ring. Replace gear, repack housing, put hub and motor back and start slicing. Routinely check to make sure gear is lubed.
Oct 30, 2008 | Berkel 827E Gravity Feed Deli Meat Slicer
Berkel 827E Gravity Feed Deli Meat Slicer Logo
1,891 people viewed this question
Top Berkel Kitchen Appliances - Others Experts
Lawrence Oravetz
acmservice
ray gallant
Are you a Berkel Kitchen Appliances - Other Expert? Answer questions, earn points and help others
