I can get the metronome to work but I cannot seem to alter the speed at which it goes.
The metronome speed is controlled by the Tempo setting. The metronome controls only adjust the volume of the metronome and if the metronome is heard on the input or output recording. The R24 manual is available here: http://www.zoom.co.jp/downloads/r24/manual/ . See page 20 for setting the Tempo. The Tempo button is below the Tempo label to the left of the LCD display on the right side of the Zoom R24.
I hope this helps.
Testimonial: "Thanks Cindy, now I just have to work out why it wont turn off, even when I go into 'tool' -->Metronome-->Off, it is still heard clicking on the track I'm recording and the tempo light still flashes. Bye for now, Lea"
SOURCE: I HAVE A ZOOM R24
Hello, CONTROL SURFACE SETUP 1. Select "Preferences" > "Control surfaces" > "Setup..." from the "Logic Pro" menu. This opens the "Setup" window. 2. Click on the top left "New" and select "Install" from the pull-down menu. 3. Select "Mackie Designs/Mackie Control/Logic Control" from the list in the "Install" window and click the "Add" button. "Mackie Control" will be added to the setup window. 4. Click the "Mackie Control" icon. Then, from the top of the list at the left set "Out Port" and "Input" to "ZOOM R16_R24" using their pull down menus. FUNCTION KEY SETUP 1. Select "Preferences" > "Control surface" > "Controller Assignments..." from the "Logic Pro" menu. This opens the "Controller Assignments" window. 2. From the "Zone" column select "Control Surface: Mackie Control." Change the functions as you like. 3. Controls F1~F5 correspond to the F1~F5 keys on the R24. The above procedures are for Logic Pro 9. The names of the menus, for example, might be different in a different version of Logic. Make sure you have run all the MAC OSX updates from your System Menu > Check for updates. This device needs full USB power so don't run it off a USB hub unless its a powered one.
So I assume when you say you downloaded the latest drivers, you are talking about the version 1.3.0 from this source: http://www.zoom.co.jp/downloads/r24/
Ok so to configure Apple Logic Pro to use this control surface follow these instructions:
