Question about Rheem Heating & Cooling
What size furnace filter for Rheem 80PS05NAR01
Previous owner stuffed in a 14x25x1 filter, it looks like the wrong size.
1 Related Answer
Anonymous
SOURCE: Filter location? Rheem Classic Super Quiet 80, RCBA 2457GG14XI
Open the two side panels. The filter is at the bottom held down with a wire spring. Release the spring and the filter can be removed.
Posted on Jul 17, 2010
Looking for the code number for the factory installed radio
the code number is included in ur owners manual, there will be a booklet for ur radio with the code number. find ur booklet, but if the previous owner has done what they should have, the code will have been removed from the book and well your stuffed really, unless its still there as i was lucky enough to find with my recent car.
Jun 19, 2010 | 1997 Honda Accord
Oil filter
I looked at the filter that came off and the part that you screw the filter on was not the same size. The K&N filter was much smaller. The filter that came off the bike was a Scotts cartridge filter one of those that you are suppose to just clean and not replace. Did someone spend a lot of money on this and change out some parts so now regular filters won't work? I'm kind of at a loss here I would like to just start using K&N as the other scotts cartridge o-ring was leaking. Anyone have experience with or seen this? What do I need to do? Thanks in advance for any help.The Scotts filter is a metal screen/mesh and IMO, will not filter as well as one with a paper media like the OEM or afaik a K&N. It's extremely unlikely that the Scotts filter required some type of insert that changed the thread pitch/size on the engine, and much more likely you have the wrong K&N. You want to make sure there isn't an o-ring from a previous oem filter stuck to the engine casing, with the Scotts filter beinbg screwing on over it. It is very possible for those o-rings to stick to the engne, ie pull out of the filter, even if they've been lubed before being spun-on. Good luck,,,
Nov 10, 2008 | 2000 Ducati MH900e
Oil filter
Nov 10, 2008 | 2002 Ducati 900 Sport
Oil filter
Nov 10, 2008 | 1979 Ducati 900 GTS
Oil filter
Nov 10, 2008 | 2003 Ducati 620 Sport
Oil filter
Nov 10, 2008 | 1986 Ducati 500 Pantah
Oil filter
Nov 10, 2008 | 1982 Cagiva SST 350
Oil filter
Nov 10, 2008 | 2000 Cagiva Roadster 521
Heating & Cooling Logo
149 people viewed this question
Top Rheem Heating & Cooling Experts
Lawrence Oravetz
ray gallant
 Russ Hill
Russ Hill
Are you a Rheem Heating and Cooling Expert? Answer questions, earn points and help others
