Televison & Video Logo
Anonymous Posted on Jun 01, 2012
Timer is lock replace bulb - Televison & Video
  • Anonymous Jun 15, 2012
    After a power outage, the green light kept blinking. The tv will turn on for about 10 seconds and turn back off. There was a message to replace the bulb, did that, but sill won't stay on, even after hitting the reset button. I did some research and saw that the timer is locked? Need to know how to unlock the timer.
Anonymous
Level 3:
Top Expert:
  • Master 14,553 Answers
  • Posted on Jun 16, 2012
Anonymous
Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2715259
Points
48227
This set has all kinds of problems--
try the self check:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
I have a Mitsubishi 60inch 60737 replaced the bulb last month.now it keeps cutting off,cleaned the filter before.someone said to reset bulb timer,how do I reset it.
The Lamp timer will not cause it to shut down. The timer should have been reset when you first turned the TV on after replacing the bulb. Make sure your bulb is an Osram brand bulb. If not, then you do not want to use it as it may not be very good.
Have a first alert et220 timer. After setting it and turning back to current time, pm light goes out and clock does not run. Manual switch works fine
Timer is not identified for certain. Expert does not have instruction manual and can only guess at cause of problem.
For example not all timers are rated for CFL or halogen bulbs.
Loose light bulb filament, or loose light bulb, or dirt in light bulb socket can cause problem, replace light bulb.
Conflicts in timer programming can cause problem with digital timer.
Read more options listed below:
1) Add a comment and describe timer appearance and if timer is programmable or has a rotary dial.
Describe what buttons appear on timer.
2) Take photo of timer and post on flickr and add comment with link to that photo.
3) Scan your timer instructions into file format. Post this file to Flickr and then add a comment with link to those instructions.
Timer clock not working. can it be replaced?
You posted under malibu power pack.
Power packs do not have repair parts.
Occasionally folks write fixya saying they took power pack apart, but nobody reports repairing transformer or timer.
'Harry' wrote fixya with helpful information.
His timer stopped working so he bought cheap plug-in timer, set power pack to override, and then plugged power pack into cheap timer.
Harry said his power pack has 5 year warranty and he was negotiating with Malibulights.com for replacement. No word how that came out.
Best I found are tips for next power pack that might save money:
The reason I add tips now, before power pack needs replacement is some fella wrote fixya.
He bought 500 Watt power pack to replace 300 Watt > thinking bigger was better.
Power pack burned out. Here's why:
a) Match wattage of bulbs with wattage of power pack
Lets say you have fifteen 20 watt bulbs = 300 watts, so install 300Watt power pack
b) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
c) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
d) When working on bulbs, unplug power pack or power pack may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
1helpful
I have a Malibu 200 watt transformer with timer and I'm not sure why the timer is not working. Is there an instruction manual on line that I can read to see what I should do?
Malibulights.com has manuals.
http://malibulights.com/customer_service/owners_manuals.aspx
People post malibu questions on Fixya each day.
Some people report being able to take apart power pack and timers, but nobody reports being able to fix power pack once it stops functioning.
If you can get manual override to turn lights on, 'Harry' wrote to fixya with some help.
Harry also said his power pack has 5 year warranty and he was negotiating with Malibulights.com for replacement. No word how that came out.
There are no parts for power packs.
The reason I add tips now, before your power pack needs replacement is some fella wrote fixya.
4helpful
2answers
I NEED A REPLACEMENT TIMER (PB912M10).
1.remove timer from power pack. this includes all wiring to timer and switch.
2. buy a timer at Home depot.
3. plug power pack into timer,
4. reattach low voltage output wires to garden lighting system or whatever you use the low voltage for.
this is the second time I had to do this remedy. the timer that comes with the power pack really stinks!
I have model ml600twsn 600 watt intermatic timer for my outdoor lights.Recently I have been unable to set them to turn off an on automatically. I can manually. what should I do?
You have malibu-type low-voltage transformer.
There are no repair parts for this type of timer, and nobody reports being able to fix timer once it goes bad.
1) "Harry" wrote to fixya with a work-around: He bought cheap plug-in timer, set malibu timer on override, and plugged malibu into wall timer.
2) Harry also said that his timer has 5 year warranty, and he was negotiating for replacement.
Contact Intermatic:
http://www.intermatic.com/customer%20service.aspx
3) Buy another timer:
http://www.amazon.com/Malibu-Intermatic-600watt-Professional-Transformer/dp/B000PGPO50
4) I found tips for next power pack that might save money:
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
d) When working on bulbs, unplug power pack or it may burn out.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 27, 2011 • Garden
2answers
I lost the small clip that is inserted into the timer at the time yo want the lights to come on,.
Trippers for low voltage timers are not available at Malibulights.com or Intermatic, or ebay.
That explains why folks ask power pack questions on fixya instead of finding results at the manufacturer's website.
New Malibu power packs are electronic and not mechanical
'Harry' wrote me about a work-around for lost trippers.
He bought ordinary 3-prong wall timer, and then set malibu power pack override to ON, and then plugged power pack into wall timer. 3-prong timers sell for $10 at Walmart and Target.
http://www.amazon.com/Woods-59204-Weather-Outdoor-Repeats/dp/B0014WRNNK
http://www.smarthome.com/56006/Woods-13571-Indoor-and-Outdoor-24-Hour-Mechanical-Timers-2-Pack/p.aspx
I put my busted power pack on a remote timer, but I like timers.
http://www.amazon.com/Woods-32555-Weatherproof-Outdoor-Converter/dp/B001Q9EFUK
My research into power pack issues resulted in tips for maintaining and setting up power packs.
The reason I add these tips now, before your power pack needs replacement is some fella wrote-in.
1) Match wattage of bulbs with wattage of power pack
2) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
3) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
4) When working on bulbs, unplug power pack or it may burn out.
I've moved into a house with the ml300rtw timer and I dont know how to set it . I've tried but it comes on at the wrong time. What am I doing wrong?
http://malibulights.com/docs/pdf/8100-9300-01.pdf
Here is the 300Watt power pack manual with detailed setting instructions
Replacement parts are not available for Power pack or timer
Couple things to remember:
Power pack has to have correct number of lights
For example, you need 15 - 20Watt bulbs
15 x 20 = 300 Watts for 300 Watt power pack
If you have fewer bulbs, the bulbs will burn out quickly and power pack will fail
When bulb burns out, replace as soon as possible, or other bulbs will be overpowered and then more bulbs burn out
Up-vote if this helped. Thanks for the feedback.
1helpful
52 inch zenith shuts down after 10-30 seconds
Bulb must be replaced before viewing will continue.
2answers
How to reset lamp timer
Go to the menu and you'll find lamp timer section.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
