Question about Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony KV-34HS510 won't turn on
The TV won't turn on, and red LED flashes.
    Top Expert:
  • Sony Master
  • 76,237 Answers
The power supply regulator section will have the fault.
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainement equipments.
Pull up older posts. You can get all details.
Site is listed in Google, and you can locate it either at the bottom part of first search page, or at the top of second page.
Click on associated ads too. Sometimes, it might help you.
Posted on Jun 01, 2012
5 Suggested Answers
Anonymous
SOURCE: standart television
How to change TV setting to video mode so I can connect a VCR/DVD combo player.
Posted on Mar 25, 2008
Anonymous
SOURCE: Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
1. Place set on flat solid surface (garage floor or driveway).
2. Bang into it with SUV 3 or 4 times.
3. If set fails to respond, crush against garage wall or drive over it
Posted on Jul 09, 2008
Anonymous
  • 563 Answers
SOURCE: My Sony TV: FD Trinitron
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 12, 2009
Chi Chu
  • 8457 Answers
SOURCE: KV-HX32 SONY WEGA TV
The hight voltage transformer it dead.The FBT(The flyback transformer is dead)The block of plastic with the red wire with a cap hook to the CRT(the tv tube).
Posted on Aug 25, 2009
Testimonial: "Thank you so much"
Anonymous
  • 178 Answers
SOURCE: have a kv-34hs510 wega that will not come on. red
This is a common failure with this set, it is in the power supply, switch mode regulators in the ps need replaced, the repair would be typically cost around 200 - 250 from a shop to repair. if you want to fix it yourself i can get the part numbers just post back and let me know if you are a do-it-yourself er.
Posted on Sep 25, 2009
How do I connect wireless headphones to my sony kv34hs510
Are your headphones blutooth or infra-red? Is your Trinitron Blutooth or infrared enabled to allow you to listen to it thru your headphones? If so, there must be an on/off switch that would actuate the Blutooth or infrared meachanism on the Trinitron itself. Otherwise, you WON'T be able to hear sound.
Sep 19, 2012 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
Tv will not turn on. red light blinks but nothing happens. sony wega kv30hs510
How many red flashes? Mine is flashing twice every 5 seconds and ended up getting a tv engineer to have a look. He has confirmed a faulty transformer approx. £120 to replace
Nov 23, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony Wega KV-34HS510 standby blinks 7 times in red
Hi and welcome to the site,
Initially, the Sony KV-34HS510 uses the DA-4 Chassis. On this chassis, 7 blinks refers to the fault "Horizontal Deflection Stopped" indicating a problem with the horizontal section. Offhand, check, replace the HOut transistor and have the FBT (flyback transformer) ring tested.
Good luck and thank you for asking.
Aug 19, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony TV WEGA wont turn-on. stand by LED
line o/p transformer &transistors are gone .. any service person can replace them
Apr 22, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony Trinitron won't turn on
this is the (OVP) over voltage protection,the unit goes into standby mode,there is a problem in power supply circuit,you need a ohm meter ,check T603 & R672.......you can get parts at Encompass Disturbution #1-800-638-3328 hope this helps.good luck
Feb 15, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony trineton KV-34HS510
let me know how many times standby light flashes. this info will help me to assist you to resolve tv problem.
Sep 05, 2008 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony FD Trinitron WEGA KV-34HS510 34" TV Logo
71 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
