SOURCE: need help getting to an cleaning stuck unloader
The cart body makes this process a little confining but it can be carried out without removing the pump from the motor.
Diagram courtesy of:
I have worked on my washer for the last 2-3 years to keep it going but I've opted to replace the pump this year. My replacement is an "AR RMV2G25D" (~$170) .
SOURCE: I have a Karcher HD3500 and was told Imay have a
Hi
The unloader valveis HERE
If you go to D-2 it is part numbers 8 to 13. If it is stuck it is not only important to free it up but also make sure no o-rings are damaged and lube it with a very good waterproof grease. Good luck.
SOURCE: Unloader Valve - Karcher Pressure Washer
where is the unloader valve locaed on a Briggs Stratton pressure washer?
