Electrical Supplies Logo
michael love Posted on May 31, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a generator on my boat that shuts down after approx 2 minutes and shows the code OF for off frequencyl. What can I do to repair the problem
Renee F
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Kohler Expert 573 Answers
  • Posted on Nov 27, 2013
Renee F
Kohler Expert
Level 2:
Prodigy:
Answers
573
Questions
0
Helped
248174
Points
680
Over frequency is overspeed and is most likely a dirty magentic pickup sensor on the flywheel
1 Related Answer
Anonymous
  • 3 Answers
  • Posted on Jun 29, 2010
SOURCE: steam shuts down after approx.15 minute
If the breaker is triping, chances are you have a undersized or faulty breaker. you want to size the breaker aprox 10% more than the max amperage output of the generator.
Example: you dont want a 60 amp breaker for a unit that will max out at 63 amps.
Mr Steam Tech Support, Mel
1-800-767-8326
2answers
Troubleshooting generators
If this unit dies under load conditions, decrease your load and try it again.
If this happens under no-load conditions, check your fuel supply. Start with the filters, then check pressure and flow.
Natural gas generator shuts down after about 5 minutes and won't keep running.
How big a unit? Model number? Alarm codes? If it runs for 5 mins check the obvious, coolant level, oil pressure and sensor,
3helpful
Champion 3500 watt generator shuts down after 1 min. Not low on oil!
You have a carburetor problem. Stuck float or clogged filter. Gas cannot get into the carb as fast as it is used. Letting it sit for a few minutes will allow the bowl to fill.
2answers
Steam shuts down after approx.15 minute
I would venture a guess that the heating element has become intermittent with a short. Wasn't so bad before, but played heck with controller due to noise from arcing, but now have a dead short when heater reaches temperature.
Acer Ferrari shuts down
This sounds like a shorted power supply or even worse the motherboard, or processor. There might be parts that are still damp let it dry out longer you could try a hair dryer on a low setting before taking it to a repair shop.
Top Kohler Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
