Question about Hayward 1 12 Hp Super Swimming Pool Pump Sp2610x15
When I turn on my pool pump (Hayward Super Pump 1.5 hp), I hear a loud humming noise like a bearing is going out. what should i replace.
This started when i lost one phase of power to my house.
Posted by Dan Moniak on
5 Related Answers
james aurienne
  • 93 Answers
SOURCE: Hayward 1 hp super Pump just hums then shuts off.
turn shaft manually wiyh pliers if somthing is stuck in propeller this should clear it
Posted on Jun 07, 2009
superdave1
  • 156 Answers
SOURCE: The pump only hums when plugged in. Any suggestions?
It sounds like the impellor is locked. Take this part off and then see if the pump is turning but before you do, some of them have a big screw driver slot in the shaft. If it does, turn it to see if you can free the impellor. I have done this many times and they will continue to work for years after. They just get stuck from rust, etc. and also being frozen a little. Hope this helps.
Posted on Jul 06, 2009
john224
John Prohaska
  • 1378 Answers
SOURCE: I have a Hayward Sp2607x10 Super 1 Hp Swimming
Thank you for posting your question here on Fixya.com.
Your motor bearings are failing. It is most often caused by a leaking pump seal. It is a relatively inexpensive repair if it is caught early enough; before the shaft is damaged from the corrosive water eating into the steel. Take it to a local electric motor repair shop for inspection. It will likely need a set of 203 bearings and a 201 seal. All told, depending on the labor rates, it should be less than $75.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jan 08, 2010
Testimonial: "Excellent...changed the bearings and replaced the front seal and all is well...thank you so much!"
MOTORWIZJ
Jay Finke
  • 1389 Answers
SOURCE: I have a Hayward 1 HP pool pump. I have to
hi ...the two yellow go on one side of the cap and the red /white go on the other.. like two on the negative side of a battery and one on the pos .. your pool pump repair guy longwood fl
Posted on Apr 07, 2010
Anonymous
  • 64 Answers
SOURCE: I have a Hayward Max-Flo II pool pump and it is
The bearings have likely lost their lubrication and have failed. You may be able tot find a local electric motor repair shop to replace the bearings. It really is not a diy project. However, if you can't find a local shop to do it, most folks replace the motor.
Posted on May 29, 2010
Switch is turned on but pump would not run. shaft turns by hand
It's junk made by Hayward. I've gone through two motors and am starting to hear the familiar noise of another motor about to fail.
Jul 05, 2012 | Hayward Pool Products Economy 1 Hp Above...
My hayward 1hp super pump hums when i turn it on but doesn't turn or pump it eventually trips the circuit breaker inside
Inside pump is a difram , it most likely is stuck, some times if you shut off pump, turn back on a few times it might release itself, but most likely needs to be replaced. Let me know, mike from fixya.com
Jun 08, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
Turn breaker on to hayward pump 1 1/2 hp model C48L2N134B1 just heard a humming noise and shut off
DIRTY START SWITCH OR AND COULD BE THE START CAPACITOR OR RUN CAPACITOR,. RUN CAPACITOR IS ON TOP OF THE MOTOR. I WOULD SUGGEST YOU TAKE THE BOLTS OUT AS PICTURED AND BRING IT TO YOUR LOCAL POOL PUMP REPAIR GUY WITH FREE TESTING.. SEARCH YOUR AREA FOR HIM ..JAY LONGWOOD FLORIDA
May 22, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
I have Hayward Centurian SE 2 hp pool motor pump,around 15 years old. Just the other day it started making a loud whining noise. Is there a quick fix for this?
if its whining but still spinning, the bearings are done. If it just makes a loud noise, the capacitor could be bad or the bearings have seized.
Jul 04, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
My haywood pool motor is loud. Think it may be
Nope.... just replace the motor.... Some shops will redo bearings, but usually a 30 day warranty and a long wait.. Walk out the door with a new one with usually a 1 year warranty...
Jun 17, 2010 | Hayward Pool Products HAYWARD 1.5 HP 2...
Hayward 1 hp super Pump just hums then shuts off.This is an inground pool
Jun 07, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Pool pump is very loud
loud pumps are most times caused by bad bearings and need to be replaced or better yet replace the whole pump new bearing cost about $100 to replace but not always easy to find someone to do hope this helps
Mar 13, 2009 | Hayward Super Pump 1 1/2 - Hp for In...
Hayward 1 12 Hp Super Swimming Pool Pump Sp2610x15 Logo
202 people viewed this question
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
