Computers & Internet Logo
Does not boot, no beep, no display, fans running on high speed
From one moment to another the desktop computer does not boot, shows no display, fans running on high speed and harddisk light is on. (also the cd and dvd units are running for a short time).
  • Anonymous Jun 02, 2012
    Motherboard Asus p4sd-la (yale). Computer HP Pavillon t730m.
    There are NO beeps. Problem persists.
    Already tried: clearing CMOS (BIOS reset), changing memory, disconnected all PCI cards and CD/DVD drives.
  • Anonymous Jun 05, 2012
    Still no solution. Also tried with a different PSU. Breadboarded motherboard with minimum configuration.
    It really seems to be the CPU or the motherboard. CPU gets normal temperature, but this is a poor indicator to know which one of both is malfunctioning.
General Systems Consulting
    Top Expert:
  • 5,051 Answers
Try blowing the dust out of the inside, around the vents, around the fans and by the cpu and heat sink.
Also remove the fan as it sits on the cpu and heat sink. Then remove the heat sink that sits on the cpu, then remove the cpu by releasing the latch on the side of the bay it sits in (remember how the cpu goes back into the bay). Now clean off the old dried up thermal paste on top of the cpu and on the heat sink that sits on the cpu. Put the cpu back into the bay and secure the latch. Apply a fresh coat of Thermal Paste to the CPU and Heat Sink. Put everything back together then reboot.
If the thermal paste has dried or is too thin to keep the unit cool it's like metal touching metal and shorts out the system so it can't boot.
Posted on Jun 03, 2012
2 Related Answers
Anonymous
  • 952 Answers
SOURCE: CPU fan runs at high speed and won't boot
Change the setting in the BIOS menu. reboot your computer.. when you see the dell logo.. press F1 (or F2 if F1 doesn't work) button until you see the BIOS screen. Check for fan options and change it
Posted on Jun 20, 2009
Anonymous
SOURCE: Dell Optiplex GX280 -ABC LIGHTS LIT UP IN BACK USB-HIGH FAN SPEED
system halted my pc help
Posted on Feb 25, 2010
I hear a beep sound from cpu with fan running at a high speed and there is no display.....plz help me oout to fix this problem
check the RAM card, remove it, clean if there is any dirt, you may put it in another slot...if still beeping, check with another RAM card if you have, or check this RAM with another computer.
I have a a1630n and suddenly when I turn it on, the fans run fast and screen stays black. No beep. let it sit over night and on the first boot up the screen will go to the windows xp logo and than go...
Alot of problems with the HP.
First thing is make sure when you changed the battery you would need to check the jumper that allows you reset the BIOS and let you use the computer.
The other is the fan speeds it normally should go a little high not so high but in your case the CMOS battery that was installed could cause some things not to work especially if it supports PCI-E. The motherboard in your system must have a dual video connector. One is on the board and one is on the PCI-E. Make sure the monitor is plugged into the right port. It should work after that. If not remove the PCI-E card and see if it works with the onboard connector.
What lights should be on when the computer boot up. sony vgc-rb34g desktop . power on fans run at high speed keyboard lights flash hard disk light flashes mouse light on no beeps or codes no display on...
You may possibly have a bad video card and a bad circuit on your motherboard. I would have the motherboard replaced. Some motherboards come with video cards, so once it is replaced, you may alerady have a new one with the motherboad part. If you not versed in doing this, you may want to get a professional to do so.
I have an a1620n HP desktop and I had to recently get a new PSU. Ever since then the cpu fan is running very loud at its max speed (around 4000rpm). It is quiet when the computer boots for a few moments...
What kind of fan is it and what are the volts and the amps it makes a difference if they are not close or the same as the original/ is it plugged into the mobo or is it a tap in on the power supply's large white y/r/b/r/wires this kind is not good for the cpu fans. let me know i will help
2helpful
3answers
2helpful
3answers
Dell GX280
Same problem... orange power light, fan starts slow and builds up to very high speed.
I removed my video card and SIMMs --> it beeped on boot and the fan did not speed up.
Put one SIMM back in --> booted fine, pressed F2 to view BIOS. Memory reported fine.
Put all SIMMs back in --> all fine now.
Marvin
Marvin
