Question about Mitsubishi WS-65869 65" Rear Projection Television
Washed out picture
Picture is washed out except for when the antenna menu is called up, then you can see picture in perfect color in the background. just changed out the convergence IC (V19 chassis has only one) also CRT's are snapping or crackling more than i believe they should, probably related to picture problem. Found an electrolytic cap loose on signal board and resoldered. Any ideas?
Posted by paul holland on
5 Related Answers
Anonymous
  • 398 Answers
SOURCE: Mitsubishi WS-55908 Convergence Issue; need IC 7A00, Panasonic MN12857k MA2
Sorry, but when the coolant leaks down onto the small signal board, that board will never work right again. The fluid penetrates the board itself since the board is double sided and has many feed-throughs. The fluid gets under the surface mount parts and just eats through the copper traces, part leads and board itself. After trying many times to clean and restore those boards, not one has ever worked right again. The boards are NLA from Mitsubishi, so the set is done.
Posted on Aug 30, 2007
Anonymous
  • 1153 Answers
SOURCE: mitsubishi 60" projo tv model vs-60705, blanking bar
Also info at www.ctechnicians.com
Posted on Dec 06, 2007
robert landry
  • 96 Answers
SOURCE: MITSUBISHI WS 65807 RED CRT OUT
It' sound like you have a bad crt, to make shure, just disconect the red crt baord and green crt board next to it and move then so you can try the red crt board on the green crt. If it does the same problem in witch I realy thought it's your video or hight voltage sounce on that board. If you get no problem well it's your crt.
I can almost garranty it's your crt.
Bob
Posted on Jan 19, 2008
Anonymous
  • 927 Answers
SOURCE: vs-45607 Vertical Hold Problem
Good Day; Just replace the caps first, 99.9% fix if not replace 9v regulator. Good Luck, big IRISH.
Posted on Nov 24, 2008
Anonymous
  • 167 Answers
SOURCE: Mitsubishi WS-55859 55in Rear Projection CONVERGENCE won't correct
HELLO YOU FIRST NEED TO UNPLUG THE SET , THEN TAKE OFF THE BACK OF THE SET. AND LOOK FOR TWO LARGE SILVER HEAT SENK'S THE IC CHIP'S WILL HAVE STK-393-110 ON THEM.!!! WILL BE SCREWED TO THESE HEAT SENK'S WITH SCREW'S AND SOLDER TO THE BOARD ON THE BOTTEM OF THE BOARD,!!! WELL "GOOD LUCK"
Posted on Nov 25, 2008
WHEN I PLUG INTO ANTENNAE--I GET " NO SIGNAL"---BUT I KNOW THAT THERE IS A SIGNAL BECAUSE I GET A PERFECT PICTURE ON MY SONY COLOR TV? HOW CAN I GET THE OLEVIA TO RECOGNIZE THE ANTENNAE SIGNAL?
You'll need to use the Olevia remote and press the MENU or SETTINGS button. The choose the SETUP or MEMORIZE CHANNELS option. MEMORIZE CHANNELS may be in an ANTENNA screen.
When you memorize channels you'll need to set the option for Antenna or Cable TV then have it memorize channels.
The television will run through each channel looking for signal and memorize those it finds. Sometimes it finds a very weak signal and you'll need to manually remove some.
Oct 04, 2015 | Sony Televison & Video
Sony flat screen tv- model KDL 40S5100
if you don't have the remote, you can use the channel and volume controls navigate you thru the menu. if all of your settings are to the left. then yes you will have no color and a dim picture, if any
Dec 11, 2017 | Televison & Video
Mitsu ws65869 picture fine in antenna menu only
May need to go to the hidden OPTION menu and do a factory reset. It is done with a 4 digit number code specific to the model number and requires the use of the Mitsubishi remote that came with the set.
May 31, 2012 | Televison & Video
Picture color washed out
have authorized servicer do a memory intialization this is ussually for a pinkish or reddish picture
Mar 26, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
The picture went fuzzy (color alignment).
craighirman,
try going to the antenna input from the menu screen, then trying to do the auto focus, or manual focus. My Samsung won't let me do the auto focus unless I'm looking at the antenna for some strang reason.
Oct 18, 2008 | Samsung PCL545R 54" Rear Projection...
Tv repair
Your tuner (in the tv menu) is probably still set on "cable", but it should be set on "off air" or "antenna". When you first turn it on, it looks for a cable signal and when it can't find one, it automatically searches for an "off air" or "antenna" signal. Once it finds a signal, then it stays on and runs ok. If you shut it off, then it has to go thru all this again.
There is a very high probability that this is your problem (about a 99.99% chance). Just go into your menu and select "tuner" or tuning or "input select" or something in that "neighborhood". Different TVs call it different names, so just put in on the option other than "cable". If you ever get cable back again, then, of course, you have to go back into your menu and set the tuner to "cable. Hope this helps.
Keever
Mar 08, 2008 | Televison & Video
Background
To change the windows vista desktop background,
start by right-clicking on a blank area of the desktop.
Click Personalize from the menu that pops up.
Click on the desktop background link.
choose your desktop background by following these steps:
  1. Select the kind of background you want from the location menu.
  2. Click on the desktop background you wish to use.
  3. Select how you want the picture to be positioned.
  4. Click the OK button
Jan 16, 2008 | Acer Aspire 3610 Notebook
Onscreen menu appears greenish
call tech and suggest to balance your screens ..they will know the procedure.
Nov 02, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Background Color
1) In the Applications Menu on your copy screen there should be a option to turn on or off a background color fill. Turn it off and try. If it still comes out try hitting panel reset. If this doesnt work. 2) You have a bad Image Unit. Change the yellow image unit. 3) You may also have a bad write unit. Pull out the four write units and check the yellow write unit. It may have gone bad in which case it needs to be replaced.
Jun 12, 2007 | Minolta CF1501 Copier
Background
Hi Adrien, the easiest way to set a picture as a Windows background is to open the picture in your web browser and right click on it. A menu box should appear, about half way down you should see an option labeled *Set as Background*. Left click on that option and Windows will automatically use that picture as you background image and tile it to fill your entire desktop. Alternatively if you have Windows XP and use the Windows Picture and Fax Viewer program to display the picture the process is the same except when you right click on the picture the selection will be *Set as Desktop Background*. When you select that option it will do the same thing. If you don?t like the tiled effect right click on the desktop and select properties from the popup menu. In the display properties box that appears click on the Desktop tab, and in the lower right hand corner you will see a field labeled *Position*. Left click on the pull down arrow and select center or stretch, depending on what effect you want. Let us know if you need any other help and don?t forget to rate the posting.
Jan 03, 2007 | Dell Inspiron 1150 Notebook
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
Paul Bade
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
