Might be a blocked filter or drain - Clean your filter out first - its located at the front or the side of the majority of machines nowadays and they are usually easy to pop out and clean. If that doesnt work try pouring caustic soda or one of the drain cleaning products from the supermarket down the sink to clear it.
Mercedes wheels
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
heatman101
