It worked a few days ago. When i went to plug it in, the charger (power Brick) light will not stay on if i bump it by accident, It wont stay of for long periods of times also. I hope its just a simple fix :/ Everything is on my computer.
Sounds like power charger not working properly or cpu is bad. this will happen sometimes too. it will turn on stay for a few seconds and then power down to prevent damagel
here is blink codes to help trouble shoot the problem
http://support.hp.com/us-en/document/c01732674#AbT2
SOURCE: Laptop battery wont charge?
It could be the battery needs replacing ... it shows that the battery is charging but it doesn't keep the charge .....
SOURCE: Laptop Compaq N610C did not powered ON
Remove your battery - start the unit on A/C then after booting up refitted battery.
SOURCE: No start after pushing Power button
I think you have to use the power DC to get the laptop on.
When it starts and windows is running. Check the power plannings.
Some configuration turn the battery charger of and will not
charge the battery!
Try to start up in safe mote ad choose save with a dos prompt.
If get in this. Press ctrl+alt+del to get the tas manager.
Open a new task. in C:\windows\explorer.exe you will get
the browser starting. Its easier to work then to type
everyting.
Go to the control panel and open the power planning.
Here you can change how the power must act.
When you're don press again ctrl+alt+del and choose from the
menu to shutdown or restart your pc.
I had the same problem after one month an figger out that the
battery woulden't charge at all and checked the power planning.
After that the battery charge again everytime when I use the power DC it charge the battery and stop charging when the battery is fully loaded.
You can see when you close the lid the power LCD light up
thats meen that the batery is charging and when its full the light
goes off.
I hope this will helps you.
SOURCE: Compaq M2000 laptop lighting bolt flash 3 times wont start
Could be a bad mother board or a hard drive..see if you can connect the hard drive with a USB on another machine and run a test on it...
SOURCE: Laptop won't switch on
Your laptop went to sleep mode and could not wake up. Press and hold the power button for about 10-15 seconds. It will turn off and you should have no lights at all unless you have the AC connected.
Turn it on back again and it should be fine.
Check your power options under control panel and see the options for sleep or hibernate and disable it so that it wont happen again.
Hope this helps.
