Question about Precor EFX 5.23 Elliptical Fitness Crosstrainer
Error 30 for elleptical precor efx5.23
ERROR 30
Posted by nishant on
Sportsmith LLC
  • Precor Master
  • 918 Answers
Precor Error 30, 31, 32 and 33, Communications Error Probable Cause 1. Bad interconnect cable between upper PCA and lower PCA.
2. Interconnect cable is mistakenly plugged into the CSAFE connector at the upper PCA.
3. Elliptical 5.17 equipped with old software version 1.01 in upper and lower PCA.
4. Upper and lower PCAs have mismatched software.
5. Another component plugged onto the PCA is overloading the +5VDC power supply.
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
  1. Test unit with a know good interconnect cable or test the interconnect cable for continuity. Replace interconnect cable if necessary.
  2. Disconnect the interconnect cable from the CSAFE connector and attach to the proper position on the upper PCA.3.
  3. Replace the upper and lower software of the 5.17 elliptical with the most current versions.4.
  4. If one of the PCAs is found to have software version 1.01, replace it with the most current software version.
  5. Disconnect all components from the upper and lower PCA leaving the data cable connecting between the upper and lower PCAs and the AC power going to the lower PCA. If the unit shows any error other than the error 3x, reconnect components one at a time. Reset power between each newly connected component until the error 3x reappears. Whichever component was last connected when the error 3x reappears, is the cause for the error. Replace the faulty component.
  6. Test unit with a known good lower PCA. Replace the lower PCA if necessary.
  7. Test unit with a known good upper PCA. Replace the upper PCA if necessary.
Precor Error Code 30 31 32 33
Posted on Jul 08, 2014
How to fix err,30 on canon t3
Have a look here for error code 30
http://www.canon.co.uk/support/consumer_products/product_ranges/cameras/eos/error_codes/
Jun 20, 2014 | Canon EOS 1100D Rebel T3 Body Only Digital...
Error code -SE-
Hi maaki41,
The error code SE stands for a keypad is held down for longer than 10 seconds. If you were not holding down a button then you have a defective key pad because of the sensor error. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
May 17, 2011 | Maytag Over-the-Range Microwave
During reheat and popcorn settings - the error code F4 appears
Hi hoodrd,
If you are encountering F4 error code from your Amana oven this is because you have an Open Oven Temperature Sensor. This error requires a replacement of new oven temperature. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call.
Hope this helps.
Jan 17, 2011 | Amana ACO1860 Microwave Oven
Error 11
ERROR-11, 12, 17, 30 Dirty disc Clean disc.
ERROR-11, 12, 17, 30 Scratched disc Replace disc.
ERROR-10, 11, 12, 15, 17,
30, A0
Electrical or mechanical Turn the ignition ON and OFF, or switch
to a different source, then back to the CD
Feb 20, 2010 | Pioneer DEH-1800 CD Player
Error 12 and 15 what is that
30, A0
Feb 18, 2010 | Pioneer DEH-P2900MP CD Receiver...
My maytag oven has a function error. F5 and F3
Hi sorianocynth,
Maytag error F5 and F3 do have different indications. Error F5 means watchdog and hardware conflict. The only way to resolve this is to replace clock (ERC). On the other hnd, F3 means you have shorted or open oven temperature sensor (RTD). Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. When they send out the part detailed instruction will be provided.
Hope this helps.
Jan 19, 2010 | Maytag 30 in. Electric Single Wall Oven...
Windows XP Error: category 102 event id 1003
look like a system crash.
try to go into save mode and do a scandisk
if not, remove any newly install hardware or software.
restart the laptop.
Nov 10, 2008 | Microsoft Windows XP Professional
PHASER 7700 ERROR 30
try this
The following functions will generate a Tech Rep Fault:
  • Error: 30: Belt Home Too long
  • Errors: 12, 13, 14, 15: ATC-YMCK Sensor Fail
  • Errors: 40, 44: Fuser Main/Sub Lamp Temp Too High
  • Enter Service Diagnostics
  • Highlight NVRAM Access and press OK
  • Highlight Clear Tech Rep Faults and press OK
  • Highlight the Tech Rep fault to be cleared and press OK
If you have had the error 3 consecutive times , you do need to send the snippet to the printer to clear the error. The instructions how to do it are in the download.
Other things. You may need to replace the accumulator belt.
You may have toner backed up in the waste auger, you can clean that out and replace the waste bottle.
Cause:
The plastic tab attached to the cleaning blade assembly was broken, this tab opens the cleaning blade waste assembly when the belt is lowered .
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. The waste toner from accumulator belt cleaner could not reach the waste bin and jammed the augur. This caused the grinding noise by stalling the accumulator belt motor. This causes an error 30 code to be displayed.
The belt cleaner does come as a separate part 016-1889-00 and is very easy to fit and much cheaper than a new belt assembly.
Error 30 is a Tech Rep fault. After three Error 30's, the NVRAM Clear Tech Rep Faults will need to be reset to be able clear the Error 30 message.
Mar 04, 2008 | Xerox Phaser 7700 Laser Printer
Precor EFX 5.23 Elliptical Fitness Crosstrainer Logo
238 people viewed this question
Top Precor Exercise & Fitness Experts
NOEL
NOEL
daf62757
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
