Lenovo power dvd icon showing only eps file type, but working properly. How can I make exact icon in my shortcut?
SOURCE: Lenovo T60 - Can't get beyond the the bios password prompt
press your Fn key and either F11 at the same time
if this does not unlock then press Fn and numlk
key at the same time
please let me know
your unlock will be a combination of Fn and anothe colour code key at top of laptop
SOURCE: my Cd dvd drive not working for Lenovo 3000 Y410 Laptop
ur lens is getting weak
pls try this take out the dvd from drive u will see a shiny eye like thing it is lens try to clean it in circular motions with very soft cloth used to clean lcd's and then try those dvd 's otherwise u have to get the drive replaced ur lens is weaken due to some faulty media and excessive use it is a normal wear and tear process
pls rate me fixya for my help
SOURCE: Lenovo Ideapad Y510 c drive full but d drive shows as empty
The cursor jump is probably because your arm or part of your hand is getting close to the touchpad.
I have the same problem.
You can toggle touchpad support by holding down the 'Fn' key and hitting 'F8'. (Fn+F8)
Don't forget to turn it back on when you want to move the mouse.
In regards to "local disk c:" being full. It sounds like your drive is partitioned into two logical drives.
You can use two methods in gaining space on C:.
The first option would be to move some of your documents from the C: partition to D:. (If you continue to save all of your files to C:, it will become full again.)
The second would be to re-size your C: partition using a tool such as "Partition Magic" in order to allocate some of the unused space on D: to C:. (This may take some time to complete. Make sure you are connected to AC power, you do not want your computer to go to standby or hibernate while changing partition sizes.)
Hope this helps.
SOURCE: can't use bluetooth in lenovo g430 laptop
UNINSTALL ur bluetooth device through
"ON" ur bluetooth through the switch
Control Panel->System-->Hardware-->Device Manager-->Select ur Bluetooth device--> Right Click select uninstall...
Then download the latest driver from
Lenovo Y410
http://www-307.ibm.com/pc/support/site.wss/MIGR-68104.html
SOURCE: Can't open DVD drive on Lenovo ThinkPad Tseries
Hello
Thank you for using FixYa for your problem
there is a little hole that a paper clip will slot into, thus pressing the release catch inside
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Open your computer's web browser.
Type following URL into your browser's address bar:
"http://www-307.ibm.com/pc/support/site.wss/MIGR-66973.html"
Press enter and your browser will open the Lenovo USB webcam download page.
or
Click the "lenovousbwebcam.exe" link to save the driver installation file to your computer.
Double-click the downloaded EXE file, and follow the on-screen prompts to install your Lenovo webcam.
Click the "mediaonegallery.exe" link to save the Lenovo Media One Gallery application installation file to your computer.
Double-click the EXE file, and follow the on-screen prompts to install the Media One Gallery application for use with your Lenovo USB webcam.
Restart your computer to save changes.
When you reboot your computer you can click the Media One Gallery shortcut to use your webcam
hope this helps
