Soyo SYTPT3727AB Television Logo
james hembling Posted on May 31, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 37 in MT-SYTPT3727ABMS tv power comes on and sound but no picture please help
Anonymous
Level 3:
Top Expert:
  • Soyo Master 14,553 Answers
  • Posted on May 31, 2012
Anonymous
Soyo Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718132
Points
48227
Audio but no pictureb>This is a common issue in many LCD or Plasma sets andit does not have a common solution.In most cases you need to first check for missing voltages on the power supply board and for damaged caps there. If good voltages exist then look elsewhere.LCD (not projection) sets often use a back light to provide the light source for the screen unit (display panel) so confirming the voltage for those is first-if back lights are used but not on it is either no voltage, not being turned on by the set, or bad light unit/s.In these sets there are also boards that "Drive" the panel itself. Usually the set will use two boards (some combineboth into one large board---names vary but are Inverters, Y-boards (Y means video) T-con boards etc. Usually in this case only one half of the screen will be black but it is possible for it to cause a total loss of brightness also.Plasma sets are similar to some degree but with no back light in most cases.Trouble shooting can be tedious and expensive-Taking one of these sets apart requires some skill as one wrong move and the Display panel can be instantly damaged which is fatal from arepair cost point of view.Other possible solutions include but are not limited to physical problems---loose plugs or connections (look for any plugs held down with tape where they plug into aboard). A lot of people with problems play the guessing game-buy and try a board after research which can get expensive and may not fix the set---gamble or not?I have seen sets where every single board was replaced and set still did not have a picture-means display panel is the problem.The problem can even be the "main" board in some cases -it controls the communication with the panel and if faulty can cause issues.Aside from checking voltages, connections etc. there are afew other considerations---The problem can be the display panel itself---Part cost for that is more than the set cost when new.The panel connects to the boards that drive it with either a multi-pin conventional plug or a RIBBON CABLE.The worst case is the problem is a ribbon cable etc. bad or damaged INSIDE the panel where it cannot be got at.That means if the case set would cost too much to repair.The connectors where the cable attaches outside of thepanel can also develop dirty or loose connections.Fans in units that use them can be an issue if dirty or not moving.As you can see (or not if no brightness) the problem sounds simple but has many possible different causes.Let me know if you have questions as I am here to try to help.SDTECH
1 Related Answer
Anonymous
  • Posted on Nov 08, 2010
SOURCE: have a soyo mt-sytpt4227ab for
take the back off and get to the power supply most likely you will find some bad capacitors in it they will probaly have the tops of the caps bulgeing.
A soyo tv model: mt-sytpt3727abms
What is the problem you faces with this TV? Provide more details, please. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
1helpful
I have sound but no picture, does this mean that i have no choice but to get a new T.V?
not true at all. I would try to look on the power supply first for popped capacitors that supply the 24v rail for the backlight inverter.
Having sound is a positive when it comes to repair. This means that only your screen is not lighting.
If you repair the 24v line and check the 5v feed also going to the ps_on (on) the backlight inverter and you still have no picture...you will need a new inverter.
Hope this helps!
2helpful
Our 37" series 4 (450) LCD TV sound "garbles"
Hi my name is Roety,
I can help you with your issue ,
Make sure you have the latest firmware upgrade from Samsungs website!
Also weak signal can cause this if using air signal raise or connect a better antenna
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
2answers
Power button comes on but no sound or picture
change the resistor in the relay circuit as they go high in value
also when you take power supply panel out check all caps for bulges etc.
Sharp aqous lc 37 in tv power no picture,sound
Your control board seem's defective or the inverter board (associated circuits) are bad. This is common in most TFT-LCD Tv's.......
Philips 37pf7320a/37 picture issues.
control boards on LCDs and PLASMA tvs are causing no picture , missing area , and other wierd symptoms , it will need to be tested to determine the true problem
The problem is the small signal board that is the video processor.
3answers
60pp9100d/37 60" phillips
try to check the fuse,if its broken replace with the same value.
Top Soyo Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
