Question about Mitsubishi WD Televison & Video
Mitsubishi dlp tv model wd-62627 wont power on when i plug tv in green light flas then will stop then i try to power on tv after after green light stops flashiing after oabout 30 sec red lamp light co
Tv will not power on steady red light stays on
Posted by Mike Buzonik on
SD Tech
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Inspect the lamp first to see if shattered--set has a self check feature also:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
Posted on May 31, 2012
5 Related Answers
Antonio Cruz
  • 336 Answers
SOURCE: misubishi wd-52631 DLP TV, it shuts off suddeny.
Hi, have you replaced the lamp after 2-3 yrs of usage? The lamps used by mitsubishi tend to last around 4000 hrs 1-3 yrs.It is common for the green light to light up.Other common failures are the ballast which is the board that powers the lamp.Also check if its not overheatin, dust out the fans.Heres where u can get the lamp or ballast http://www.discount-merchant.com/SearchResults.asp?Search=wd-52631
Posted on Apr 19, 2011
Anonymous
  • 39 Answers
SOURCE: Mitsubishi WD-52725
SEDI-POSSIBLY YOUR SET HAS A LOW 5 VOLT POWER SUPPLY.TEST VIA VOLTMETER ON PLUG J-9 WHICH IS ON LITE ENGINE .YOU WILL NEED TO REMOVE BACK OF SET TO MAKE THE TEST.IF 5 VOLT IS LOW BEST TO CALL A MITSUBUSHI TECH.JOE TV
Posted on Nov 30, 2007
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: WD-52525 Red lamp Indicator
usually with that model when you get a 34 eror code for lamp abnormality, its directly related to the capacitors on the Power Pwb. You can get the V26 Power PWB repair kit at the following link which repairs that issue. It contains the replacement High temp capacitors with the board location numbers and PWB identification as well as the service manual on CD. Heres the link its under their repair kit ctegory.
http://servicemanuals.vstore.ca/
Posted on Sep 04, 2008
Anonymous
  • 58 Answers
SOURCE: Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Posted on Apr 18, 2009
digitaldump
  • 115 Answers
SOURCE: mitsubishi wd-62525 sound will come on but no picture.
Your tv would turn on if you replace the only two 3300µ[email protected] capacitors on the power board . You wil notice they are bad by the way they bulge up at the top and may be leaking electrolyte a little from the tops . But the rolling lines would still remain but much less noticable.Then other symptoms will eventually appear. Truth is many many many many other capacitors need to be replaced inside the electrical chassis. Your TV would need to go to a repair shop that is expierienced in that repair because it is so extensive.
Posted on Oct 06, 2009
2006 mitsubishi tv WD 62627. Tv wont come on i hear a click when I hit the power button. Blinks green on timer for about 60 sec then goes to solid yellow light on status. Error code 46.blew fan out.
Those blinks are fault indications. From the number of blinks occur at one time switch on, you can get an idea about the fault circuit section inside it. http://electronicshelponline.blogspot.com/ Visit the site linked here to know more details about the blinking codes.
Feb 18, 2017 | Mitsubishi Televison & Video
After replacing bulb on WD-82738 still not working
How to replace the lamp in your Mitsubishi TV - YouTube
? 3:13
https://www.youtube.com/watch?v=_ONPuB5L-x4
Nov 1, 2012 - Uploaded by Mitsubishi3D
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
After replacing bulb on WD-82738 still not working - Fixya
www.fixya.com/.../t26028385-after_replacing_bulb_wd_82738_still_no...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Mitsubishi WD-82738 Blinking Green Light - Tom's Guide
www.tomsguide.com/.../id.../mitsubishi-82738-blinking-green-light.html
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
Amazon.com: Mitsubishi WD-82738 DLP TV Asse
Dec 29, 2015 | Mitsubishi WD82738 82 1080p 3D DLP Home...
How do you to troubleshoot a Panasonic Vierra tc-P46G25 TV that does not turn on?
Check for bad capacitors (they'll look bloated) on the power supply board. Also check the voltages on the power supply board with your meter ; they should be etched on the board at test point location(s)
Jul 16, 2014 | Televison & Video
Red light blinking green light steady on
THIS IS A NORMAL THING FOR UNIT TO DO
GREEN IS POWER APPLIED
AND RED IS HARDDRIVE RECORDING VIDEO DOWN
Mar 07, 2014 | Lorex LH118501C4 8 Channel 500 GB DVR with...
I need manual for mitsubishi dlp tv 62 inch model wd-62627
Owner manual or service manual?
Try to Google the model number for either or visit the Mitsubishi site for the owner manual.
May 21, 2012 | Mitsubishi Televison & Video
Model WD 62627 When I plug it in all that comes on is the timer green light at the bottom of the tv.
Replace the lamp of your tv or check it first if damage, feel free to send feed back good day and best regards.
Aug 22, 2011 | Mitsubishi Televison & Video
I have the WD 62627 model. the lamp light is on, when i power up the tv, it comes on for like 6 to 10 secs then it turns off. Does this mean I need a new Lamp?
I would say that it probably is a bad capacitor on the power supply board of the tv. What you want to look for is any round cylinders with the tops pushed up at all. The replacements are usually really cheap, it might also be the lamp, but usually when lamps go they go completely while a bad capacitor is known to cause intermittent problems that escalate into a tv only working for about 5-10 seconds.
May 03, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
692 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
