Washing Machines Logo
Question about Amana Washing Machines
How to add fabric softner to the amana washer with locking lid
My amana washer doesn't have a fabric softner slot, when I unlock the lid to add fabric softner it starts the whole load over again. How is the best way to add fabric softner to the rinse cycle.
Posted by Maree Fields on
  • Dave Pedersen
    Dave Pedersen Jul 14, 2018
    I'm guessing that maybe you are holding the button in too long and cancelling the cycle, just press quickly to pause and
    add fabric softener, if it is spinning when you press the button it won't unlock the
    lid until it stops spinning ...
    START/STOP/PAUSE/UNLOCK LID BUTTON
    Press to start the selected cycle; press again to pause
    the cycle and unlock the lid.
    NOTE: If the washer is spinning, it may take several
    minutes to unlock the lid. Press and hold for 3 seconds
    to cancel a cycle.
Anonymous
    Problem Solver:
  • 18 Answers
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
Posted on May 30, 2012
  • Dave Pedersen
    to cancel a cycle.
Jim Kara
Add softener/ sanitizer thru lid slot (indentation in top at the front of the lid, where hand lifts it up), usually located far enough over the drum to flow down into it, without having to open the lid.
Posted on Apr 02, 2019
K. Price
    New Friend:
What question are any of you answering. The issue is the washing machine was not made with a fabric softener cup, dispenser or any other means of putting fabric softener in the wash. Why Amana built this model washer without this option is a mystery. This leaves only the option of pouring the fabric softener in during the rinse cycle which requires unlocking the lid which........restarts the entire wash cycle apparently
Posted on Aug 16, 2016
  • Susan Chiodi
    Susan Chiodi Nov 09, 2018
    exactly. why do they make new washers without the cup?
  • Susan Chiodi
    I wait for the wash to end, then open lid, turn the dial to rinse spin cycle, let some water fill then add softener. such a hassle.
5 Related Answers
Anonymous
  • 4889 Answers
SOURCE: Bleach and Fabric Softner Dispenser
This is absolutely normal and you dont have to worry about it..
The reason for this:
The fabric softener compartment uses an over flow method to get the fabric softener out of its compartment and into the wash load. Water comes up underneath through a syphon tube and gently fills the fabric softener dispenser and causes it to over flow in its diluted state. The reason for this is that it is the most effective way for fabric softener to be diluted prior to hitting the clothes in the drum. Fabric softener has to be diluted before coming into contact with fabrics.
This is in contrast to how detergents dispensers work which simply flush the soap powder in to the drum by water being squirted on to it from above.
It is perfectly normal to have a fabric softener dispenser full of clean water after the wash cycle. Just lift and empty it out when you need to fill it with fabric softner for your next wash
Posted on Dec 10, 2007
Anonymous
SOURCE: whirlpool duet fabric softner problem
According to the whirlpool FAQ's page, that is normal. They stated that at the end of the cycle, fresh water is used to clean the detergent holders. Not sure that I believe them though.
Posted on Dec 28, 2007
Anonymous
  • 15935 Answers
SOURCE: kenmore washer not working
Likely the motor (or controller) is bad. Further tests are necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Anonymous
  • 116 Answers
SOURCE: Tricity Bendix washer won't take fabric softner in rinsing cycle
Your machine possibly has a defective water inlet valve which is preventing water from entering the dispenser channel to flush the fabric softner into the machine. The inlet valve in inside of your machine right where the washer hoses attach. the solenoid valves on the inlet will need to be checked with a multimeter to verify if they are working properly.
Posted on Mar 11, 2007
Anonymous
  • 1554 Answers
SOURCE: My Frigidaire front load washer will not dispense
Clean the dispenser drawer if water is introduced into the fabric softener cavity but does not dispense. Pull the dispenser drawer out until it stops and push down the release tab marked "PUSH" and then pull the dispenser out completely.
Lift the dispenser drawer cover and clean the tubes both in the dispenser drawer and the cover.
Turn the drawer over then release the conveyor from the tabs and lift it off. Clean the conveyor and the drawer thoroughly.
Snap the conveyor into the tabs back into position and then reinstall the dispenser cover making sure the tubes are properly seated.
Slide the dispenser drawer back into the drawer opening while pushing down the part marked "PUSH".
Let us know if the fabric softener dispenser still does not dispense while both the detergent and bleach dispensers dispense.
Posted on Mar 10, 2010
My Amana washer lid lock is blinking, the lid is up and can't be closed.
Unplug machine for a few minutes. Then plug back in to see if it unlocks. If not, lid lock assembly is most likely bad.
Amana NTW475OYQ1no lights or sounds. Verified power @circuit board. Someone closed lid on a shirt earlier that preventing lid to I open.verified switch waz working and the wife did a load of laundry.
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following ... Speed Queen, Amana Whirlpool ..... Lid lock lightflases; no spin cycle.
Amana Washing Machine NTW5400TQ1 Troubleshooting ...
www.repairclinic.com/.../Washing-Machine...-/Amana-Washing-Machin...
Amana Washing Machine NTW5400TQ1 Troubleshooting & Repair Help. Amana Washing Machine problems. Washer won't spin · Washer is making loud noise ...
Hello I have a AMANA washer top loader model number NTW4700YQ. The washer will do the 5 second fill when you start a wash cycle and then switches over to "lid Lock" now after this it does nothing. you can...
The lid switch is one thing to check, make sure that it is not loose or broken, IT could also be the water level sensor, they become gummed up with softner sometimes.
How to add fabric softner to the agitator
Does it have a small hole in the top of the agitator on the flat spot? if so then this is where you pour the softener.
I have a LG wave force top loader and I have a mold smell that doesn't go away. I have run the tub clean mode a few time, usually adding bleach to where you would normally add bleach. However I...
I have the same model washer and also have that gross mold smell. However, it has NOTHING to do with liquid fabric softener because I ONLY use dryer sheets.
1helpful
My lid lock button is stuck and will not unlock....when i 1st went to the washer it was on spin and lid lock and i pressed the start button which is suppose to unlock this lide but that has not...
That happened to me once. I just unplugged the machine for a few mins and it released the lock when I plugged it back in. I've got my fingers crossed that it doesn't happen again.
9helpful
2answers
Amana tandem 7300 stopped ,door is locked wash light is beeping
Door won't unlock
Did all of the water drain out of the washer during the spin? Select DRAIN & SPIN to remove any water remaining in the washer. The washer door will unlock at the end of the drain.
Is the door locked and is the "Add Garment" light on? Press START/PAUSE once. The door will unlock.
5helpful
The fabric softener is clogged with dried up fabric softener on my Whirpool Washer. How can I get it cleaned out?
You really cant take them apart without breaking the dispensers. Fabric softner is basically wax and fragrance. Add very hot water to the dispenser to melt the fabric softner. In the future, water down the fabric softner.
My front load washer will not empty out the fabric softner. I have taken out the drawer & cleaned it. It will empty out the laundry soap, but not the fabric softner
I have the same problem with mine. I found that some fabric softners worked better than others. I found Downy the worst, when i switched the problem seems to stop once i cleaned out the drawer
2helpful
FABRIC SOFTNER DOES NOT DISPENCE
Check to make sure the litle cups are set in place correctly and also make sure they are not blocked with hard fabric softner. A quick test: pour water directly into the fabric sofnter cup and fill it up,IF it siphons out, you will need a new inlet valve for that unit. The inlet valve has soliniods on it for the bleach & fabric softner.
Good Luck!
Open Questions:
Top Amana Washing Machines Experts
Mike
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
