Question about GE Washing Machines
Ge Washer won't start, lights come on but won't stay on, what do I do?
Posted by Rani Huitron on
cube2_72
    New Friend:
Go online and search for brand and model number service manual. There are probably multiple things it could be, but the troubleshooting section should point you in the rite way.
Posted on May 30, 2012
5 Related Answers
oldTech2332
Gene Meier
  • 2341 Answers
SOURCE: my washer panel will light up and the load washer
To me that sounds like the problem may be within the door switch/lock, on the doorlock asm. is a little botton that sticks out of it,look and see if its their or perhaps its broken off. What that button does is tells the washer the door is closed so it can go ahead and lock it to start the cycle,its perhaps broken off sothe machine doesnt think the door is closed and thusly wont start.
GENE
Posted on Oct 06, 2011
Anonymous
  • 72 Answers
SOURCE: GE Washer Motor over amp?
If that's the only thing wrong with it, then go to http://www.appliancepartsdepot.com
They are about the most reasonable priced place I have found.
Posted on Jan 27, 2008
RJ Williams
  • 121 Answers
SOURCE: ge front loading washer door won't unlock
I had the same problem. I didn't want to spend the money or go to the trouble of replacing the whole latch assembly with the GE latch repair kit.
I found that the plastic latch piece screwed to the door had broken and one of the two latch "fingers" was stuck in one of the latch openings on the washer. I fixed the problem by removing the broken part from the washer and drilling and countersinking very small holes (1/16" I think) in the plastic latch piece on either side of the "latch finger". I then put the broken off piece back in place and drillled pilot holes for #4 sheet metal screws in the door where the latch is located. The door liner is plastic and I think I used a 1/32 inch drill bit. I reattached the broken latch piece with two 1/2 inch stainles steel #4 flat head phillips screws from Home Depot. The screws hold the broken latch piece in place as orinilally positioned.
The repair is working fine and the door now latches like it did before the latch part broke
Or: http://www.appliancepartspros.com/part_details.aspx?image=0&part_id=2045520&pn_=WH10X10002 Same part cost $200 direct from GE
Read more: http://forum.appliancepartspros.com/washer-repair/8379-ge-washer-front-loader-door-wont-stay-latched.html#ixzz1LmNUKfTN
Posted on May 08, 2011
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: GE Washer will wash but won't drain?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Jul 24, 2011
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: My GE washer #WDSR2080DEWW washer
heatman101
Posted on Aug 13, 2011
Ge washer "lo" light when lid is closed. and won't start after it has run before
"LO" means the washer's lid is not closed
What is the model number?
Oct 13, 2012 | Maytag Washing Machines
How do you clear codes for 2004 saturn ion
Clear the codes AFTER a repair was made & the light
stayed on ?
I would purchase an inexpensive $60.00 code reader &
use that.
If you start disconnecting batteries on every vehicle you
do or will own,then bad things happen.
The radio won't work,the car won't start,etc
If you have service manuals to learn your vehicles systems,
then you can eventually know what the results will be
Again,if you fixed nothing,then the light is going to stay on
or come back
Sep 18, 2012 | 2002 Dodge Dakota Club Cab
My security light stays on & won't let my 99 gmc 6.5 diesel sierra start any solutions
Yes, the system is called Passlock, and malfunctions regularly. Go to this link for an explanation of how it works, plus some tricks and tips on how to reset it, or bypass it.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Mar 27, 2012 | 1999 GMC Sierra 3500
Washer won't start and red lock sign on front
Sounds like a problem with the door lock on the front but what and where is another question ,is the water turned on by any chance as it will not fill and could throw this light on .
Feb 11, 2012 | GE WSXH208A Front Load Washer
Ge top load washer won't agitate or spin after
what is your model number is then we can started then okay
Sep 15, 2011 | GE Washing Machines
Washing Machines Logo
348 people viewed this question
Top GE Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Mike
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
